Results 1 to 10 of 10
  1. Hi, does anybody know of an easy way to fade out clips at the end? Some are cut short and I would like to fade them out so it doesn't stop abruptly. Thank you.
  2. Member Sugar's Avatar
    May 2002
    NY, USA
    I assume you are talking about video clips shot from a camcorder?
    You can do it with an editing software such as Premiere.
  3. anything that is free and easy to use? Thanks
    May 2003
    Peterborough, England
    Any video editing software can do it. Even Windows Movie Maker 2!
  5. any other ideas windows movie maker keeps freezing on me and i can't do anything. Thanks.
  6. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    Fades are easy with AviSynth...
    AVISource('whatever.avi").FadeIn(30)
    AVISource('whatever.avi").FadeOut(30)
    (xx) = # of frames
    etc, etc
    "There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
  7. I'm sorry, but I have no clue how to even begin using that program. Is there anything simpler to use? Thanks.
  8. Member sacajaweeda's Avatar
    Sep 2003
    Would I lie?
    What programs have you tried for editing?
  9. So far I only use two. TMPGEnc and VirtualDub. Oh and some features that come with Nero DVD authoring tools, but they make a weird noise when i fade out the end. But that's about it. I'm looking for something easy to use such as TMGEnc. Is there anything?? Thanks.
  10. Might try poking around here: https://www.videohelp.com/tools?section=17#17
    But - outside of windows movie maker, don't know of other freeware editors that are simple/easy like you want.
    Always check helpfiles/instructions before leaping...
