I am converting my movie AVI file (good quality) into a MPEG-2 for SVCD and the result is not very good. Is there a problem with Studio DV? Does anybody have a solution?
Thanks.
I have Studio DV. I quickly found out that its built-in mpeg encoder is crap. If you are editing home videos best bet is to output as AVI and then convert it to SVCD. Check out the "How To" guide on the left for the tools and procedures.
I also have Studio DV and it does produce some bad mpegs. Your better off exporting to avi and then using tmpg.
I have the same problem. I complain already to Pinnacle, and they suggest me to buy the Studio 7...
I have reply that after spending my money with one product with very bad quality, doesn't make sence to think in that brand any more.
To overcome my problem, I'm looking now for Adobe.
Regards from Portugal. -
Adobe will not solve your problem. They do not include a decent encoder either. TMPGenc seems to be the best alternative.
You get the Panasonic MPEG Encoder Adobe Premiere plug-in for Premiere. It is probably one of the best MPEG-1 encoders out at VCD bitrates (quality is subjective: some people think that Panasonic is better than TMPGEnc at VCD bitrates, some people think the opposite).
In any case, you can use AVISynth to frameserve to TMPGEnc with Premiere.
Regards.
Michael Tam
w: Morsels of Evidence
PowerDirector makes final DVD files, size larger than mpg file's size, why?
By Xor2 in forum Authoring (DVD)Replies: 4Last Post: 22nd Dec 2011, 17:29 -
Captured huffy AVI, convert to mpg poor.
By davexnet in forum Video ConversionReplies: 19Last Post: 15th Jul 2010, 21:01 -
Great Quality AVI, Poor Resolution Creating Assembled video in Studio 14
By japentz in forum Video ConversionReplies: 8Last Post: 5th Jul 2010, 19:34 -
Problem With MPG files in Studio 9
By BillP2 in forum Authoring (DVD)Replies: 3Last Post: 3rd Dec 2007, 06:49 -
How to Import MPG into Studio 9
By ozab in forum EditingReplies: 1Last Post: 30th Nov 2007, 18:11
