I need a program that can shrink avi.'s kind of the same way dvd shrink shrinks dvds. Any such program?
This program you speak of doesn't exist. The only way to shrink the file size is to re-encode it. Doing so will involve quality loss. One thing that might make things easier for you would be to use Dr. Divx. It allows you to specify the output file size. Like I said before though, you're going to lose video quality.
bitmap shrinker help needed
By maduncledai in forum ComputerReplies: 1Last Post: 20th Apr 2010, 00:28 -
Dazzle dvc100 w studio 12 does it capture AVI 1 or AVI 2 or DV-AVI
By st711 in forum Capturing and VCRReplies: 1Last Post: 10th Dec 2009, 17:30 -
ffmpeg choppy audio from large avi but not small avi source file
By cybertheque in forum Capturing and VCRReplies: 9Last Post: 13th Oct 2008, 15:38 -
ffmegX v0.09w and converting avi videos into avi.ff.avi videos
By paddymick in forum ffmpegX general discussionReplies: 2Last Post: 2nd Nov 2007, 23:10 -
How To Split Single DV AVI file into Multiple DV AVI files using Time Stamp
By insysnet in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 2Last Post: 23rd Aug 2007, 12:49
