Hi guys
I just bought a DV Capture card,
when I use Ulead Video Studio to encode 1 hour video to MPeg2 DVD, it takes 5 hours, is that normal?
any other faster method with better qualities?
Thank you so much
From what I've seen, yes. Here's my newbie answer cause I'm a newbie.
If u save ur cap as avi, vdub>>frameserver>>tmpgenc/bbmpeg
If u save ur cap as mpg, xmpeg/flask>>frameserve>>tmpgenc/bbmpeg
if u have premiere and save ur cap as dv, premiere>>frameserve>>tmpegnc/bbmpeg
U should save some hours, depending on what filters u enable.
Thank you for your fast reply.
I have Premiere, should I use premiere instead of Ulead Video Studio?
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
I played with premiere 6 and it seemed easier for me to use, and the frameserver plugin (www.videotools.net) is available for it. I played with the other two ulead products and I didn't see support for the plugin.
For what I do, cutting commericals out from tv captures, flask/xmepg>>frameserver/avisynth>>cce/lsx works for me.
Converting Dual Layer DVDs to AVI (Video Footage More Than 2 Hours)
By cucuzza in forum Video ConversionReplies: 2Last Post: 17th Sep 2010, 18:54 -
Converting 6 files taking over 10 hours
By ChadBling in forum Video ConversionReplies: 3Last Post: 16th Jul 2010, 06:03 -
Auto Gordian Knot is converting to divx in 4 hours!
By szalaikornel in forum Video ConversionReplies: 8Last Post: 17th Jan 2009, 07:39 -
It took 11 hours with TMPGEnc 3 to make a 2 hour video folder
By nhbfan12345 in forum Authoring (DVD)Replies: 3Last Post: 9th Dec 2008, 14:18 -
Hours of Music without Hours of Video Data in DVD Architect
By Guff22 in forum Authoring (DVD)Replies: 3Last Post: 6th Aug 2008, 21:23
