How does a dual layer burner burn? Does it modulate the beam depending on which layer it's writing? If so, would this be how a single layer drive could be upgraded to a dual layer by updating the firmware?
Or is there really no way a drive can be upgraded to dual layer?
Hard to say when theres none around,it would seem they would need to switch burn depth by beam strength for the next layer,maybe some dvd`s can be upgraded hopefully.
by adjusting the focal point of the lasers, there is roughly a 50% intnesity loss in the beam, though enough to divet the media.
AH yes, it is important to divet the media. Fully diveted media is an absolute necessity in this day and age. 8)
The electronic components of the power part adopted a lot of Rubycons.
Dual Layer writing not working properly
By uniks in forum Newbie / General discussionsReplies: 9Last Post: 5th Mar 2009, 08:37 -
Dual layer disc error (2nd layer not burning properly - AVCHD)
By hhhgamewmx7 in forum Authoring (DVD)Replies: 7Last Post: 24th Aug 2008, 09:00 -
DVD Burner for writing Dual Layer
By StealthKing in forum DVD & Blu-ray WritersReplies: 9Last Post: 1st Feb 2008, 21:25 -
Problem Writing Dual Layer (first time attempting DL)
By brett0973 in forum Authoring (DVD)Replies: 5Last Post: 9th Nov 2007, 21:46 -
Dual Layer Questions
By cduval04 in forum Newbie / General discussionsReplies: 5Last Post: 31st Oct 2007, 11:45
