I have a dvd, Swordsman II, it plays fine on my sony player. But in my dvd-r drive, it can't even see it. No dvd found according to dvdshrink. Dvddecypter says "incompatible media". The dvd-drive in windows explorer turns to "cd-drive".
How can I make the dvd-drive recognize the movie?
are you using the latest firmware?
is it compatible region ? i.e. region 1 in a region 1 DVD-ROMWelcome to the REAL world! -
I'm not using the latest firmware. I did flash it about 2 months ago.
It played my other DVDs and other back-ups and they work fine. But when I play this one it is just not recognized. My sony is a region 1 (or U.S. forgot if US is 1 or 3) but it is U.S. Standard.
I can try the new firmware and see what happens.
But until then, any other suggestions are welcome. -
I am also using an optorite and have flashed the latest firmware but I have the same problem with every dvd that I copy. I still haven't found the answer so if you do let me know please
Are CD's and DVDR recognized by the drive?If they are then the disc is the problem.
Do you have ForceASPI drivers installed? -
For me, I've been on an older firmware, my cd's and dvd's (origs & back-ups) are being recognized. This is the first one for me to act up like this.
I tried doing the current firmware for the Optorite2203 but its on DOS.
It requires me to create a boot disk, then to extract the files to the disk, but then there is not enough room on the disk for the firmware files.
Anyone have a trick for that? Or should I start a new thread?
Also, still can't figure out why (Swordsman) that dvd is the only unrecognizeable one for my dvd-r. The previous foreign films warned me to change the region settings beforehand. But this one just is not recognized as inside the drive at all. "Please inser disc". -
The disk is not a region 1 disk I assume, and if you have changed the region on your drive 4 or 5 time then it is now perm.
Have you tried any other foreign films since you had this problem ?
I suspect that you will have this problem with any none region 1 disk. as you cannot chcnge the region on the drive anymore.
There is a hack somewhere that can make drives region free. I do not remember where I saw this though. check the tools section.
Hope that helps
RETAIL DVD plays in standalone - "No Disc Inserted" message in PC
By prattitude in forum Software PlayingReplies: 6Last Post: 28th Nov 2007, 13:07 -
Standalone Player plays only 33 mins of the resulting DivX DVD
By penguin74 in forum DVD RippingReplies: 8Last Post: 30th Oct 2007, 18:25 -
Burned DVD plays OK on standalone - not on PS2!?!
By offensekilla in forum Authoring (DVD)Replies: 5Last Post: 31st Jul 2007, 12:07 -
DVD (ISO) Plays Fine on PC, Won't Play on Standalone
By MoneyAddyct in forum Newbie / General discussionsReplies: 1Last Post: 17th Jul 2007, 22:15
