  1. OK, if you could decifer what I am talking about in that subject you are the guy I want to talk to!
    I am frameserving captured video from Vdub. I need to use Vdub because of tons of filters I added. But when I serve this to CCE 2.5 using 3-pass VBR, CCE crashes right after cretaing the first VAF file. It does this every time.
    I recently read on here that perhaps thi is a problem with the frameserver. If so, how can I serve my avi to CCE while also maintaining my Vdub filters? I heard that Avisynth might be able to do this, but how?
    Thanks for your help!
    -Shahid
    May 2001
    chicago
    go to the avisynth page and read the reference guide + scripting tutorial here: http://www.math.berkeley.edu/~benrg/avisynth-premiere.html
  3. hi
    this is what I use in Avisynth:
    LoadPlugin("C:\PROGRA~1\DVD2SVCD\MPEG2DEC\MPEG2DEC .DLL&quot
    avisource("C:\windows\desktop\test\test.avi&quot
    BiCubicResize(480,432,0.00,0.75)
    TemporalSmoother(2,1)
    AddBorders(0,72,0,72)
  4. One more think i think using 3 pass is waste of time
    I did a test where i have 5 mb avi and I try cbr one pass and multi pass.I came to conclusion that using One pass
    is faster a lot and you getting the same quality.
    Try it you'll see there is no differents in quality
    Feb 2001
    Berlin, Germany
    It depends on the quality of source of course. If you use quite a low avg+max bitrate you will need more passes.
    Why do you resize the captured avi and why do you load the mpeg2dec plugin?
    Feb 2001
    Berlin, Germany
    SHaque, is this your error message?:
    cce encoding failed: Error: Video check-sum, is different from that of previous pass.
    Source video data or time code may be different
    Please check video tape or the information file
    --- information---
    Then have a look at this topic.
  7. Thanks Truman, that is the error message I have been getting, and I will bet that patch will solve the problem!
    Thanks!
    -Shahid
