"GoBack is unable to determine which of you drives is the boot drive". I'm trying to reinstall Roxio GoBack Deluxe 3 (now owned by Symantec) after a hard drive crash a couple of weeks ago. I found this article http://service1.symantec.com/SUPPORT/goback.nsf/docid/2003030413270207?OpenDocument&sr...e&csm=no&tpre=
This can happen when one or more hard disks on the computer is a Dynamic Disk. GoBack is not compatible with Dynamic Disks and you cannot install GoBack on a computer that uses a Dynamic Disk]The only problem with this fix is that none of my disks are Dynamic ... they're all basic. My harddrives include 120GB WD ATA100 7200 RPM (15 GB partition as C:\ and 105 GB partition as D:\), 250GB WB ATA100 7200 RPM (G:\), 160GB Seagate SATA 7200 RPM (H:\) & 60GB Seagate External Firewire 7200 RPM (I:\).To use GoBack on a computer that uses a Dynamic Disk, you must first convert the Dynamic Disk to a Basic Disk.
This is a tough one ... and I know it's a long shot ... Any thoughts or suggestions?
Results 1 to 1 of 1
Unable to solve a boot problem, really need some HELP.
By blinky88 in forum ComputerReplies: 5Last Post: 24th Apr 2009, 17:17 -
How do you boot into a Linux Partition from a USB Flash Drive?
By Number Six in forum LinuxReplies: 10Last Post: 16th Feb 2009, 16:20 -
Best Way To Move Boot Drive To New Board?
By DarrellS in forum ComputerReplies: 38Last Post: 15th May 2008, 12:53 -
HELP! reactivating SATA drive everytime i boot?
By JayArea408 in forum ComputerReplies: 3Last Post: 2nd Sep 2007, 17:12 -
slave drive seems dead, but cannot boot without it
By ted demen in forum ComputerReplies: 11Last Post: 13th Jun 2007, 08:54
