What are the proper steps to creating a disc label in Photoshop and then printing the disc with a R300 printer ?
Do I create a jpeg image in photoshop and then import into Epson Print CD ?
I tried creating a tif file but when I try to import the image doesn't show up in the Browse window.
I just scan the disc, save as a jpeg, import the file in the epson program and change the size to fit the epson layout. Works great.
Posit -
The Epson CD Print Program can't import/use TIFF (.tif) files using LZW Compression. When exporting to TIFF format chose "Uncompressed" in the Photoshop filter options. Uncompressed TIFFS will appear in the Epson browzer and can be used.
This is much preferred to the lossy JPEG format... -
Why not just use the "lowest compression [photoshop setting = 12]" JPEG. I can never tell the difference between that and any flavor of TIFF or BMP.
Is anyone using a Photoshop template they're willing to share ?
What happens if my jpg image is larger than the Epson disc layout, either at the outer edges or the inner rim ? Does the Epson CD Print program ignore that part or the printer still oversprays the ink ? -
When importing the background image into the Epson Print software you can use the "image adjust" filter to determine what part of your "too big" image gets cut-off in the Epson Print template. Generally, I design my disc images based on a 119mm circle (the actual disc image I want) on a 121mm square background. The default background image import filter in the epson software cuts off the excess so the printer doesn't spray where it shouldn't.
YMMV, experiment a little, have some fun...
Thanks Umbearto,
I printed my 1st disc and it came out almost exact but needs a little fine tuning to get to the edges properly. -
Sounds like you're on the right track. I've had to fine-tune the edges for inner and outer diameter for each new media I try. It can be a mighty fine line between having excess ink bead up around the stacking ring and outer edge of the disc, or, leaving a white/silver ring left unprinted around the edges. 1mm adjustments just aren't fine enough; most of the time a .5 adjustment in inner/outer diameter in the Epson Print software is really what is needed. Oh well, Bright Lights - Big City
Happy Printing..!
Backing up DVD/Blu-ray to disk, watching movies directly from disk to TV.
By mb312 in forum Newbie / General discussionsReplies: 0Last Post: 11th Feb 2010, 16:35 -
Printing a Color label on a disk
By tealmarlin in forum Newbie / General discussionsReplies: 3Last Post: 8th Jan 2009, 11:40 -
Adding BLUETOOTH to Epson R300 using Dongle ... Which one works?
By Toaster in forum MediaReplies: 4Last Post: 13th Sep 2008, 09:19 -
Creating / converting DVDs with Devede: Disk usage bar underestimates size!
By nicolaidenmark in forum LinuxReplies: 4Last Post: 23rd Aug 2008, 00:09 -
Creating CD / DVD Label Templates in Photoshop 7.0
By Brehmstein in forum User guidesReplies: 3Last Post: 27th Dec 2007, 18:22
