Hi!
I've got some mpegs movies are cut short when played on my new system. The old system was Win98SE, Viper video card, 550MHz Athlon. The new system is listed in my profile.
The mpegs are supposed to be long (15 minutes) and the new system plays the first 2 min of video, then freezes while the audio goes on.
Can anyone tell me what's happening and how to fix it?
Thanks!
Ken
Always check helpfiles/instructions before leaping...
Isn't there some sort of patch or codec that load to make the mpeg compatible somehow? I'd like to edit and author it if at all possible.
The media player classic works btw.
Ken -
Look to the left of this page for convert and author sections. Be prepared for a bit of reading.
Yuo will also need to know the structure/formats of your mpg files. Look gfor guides on doing that - if you don't already know their details.Always check helpfiles/instructions before leaping... -
Load the files in virtualdubmod and see if you can scan past the freeze,if you still see the freeze then the file is faulty,if you can scan all the file normaly then you can frameserve out the tmpenc if you cant fix the files.
I ran the files thru virtualdubmod and I can't scan past the stop. Any other suggestions would be appreciated.
Another thing about these files is that if it is played in a player like Win MP I can play past the stop if I click on the scan bar. It seems if I pick a point on that bar, the video will advance to where it should be if played normally. However, it won't play the rest of the file. For instance, if I ran what normally is a 14 min mpeg, and if I click on the midpoint of the scan bar, it would advance to the 7 min mark, but only play for 1 min and stop at what normally be 8 min.
Ken
Converting a 480x720 2:3 short to a 1280x720 16:9 HD short.
By Cyrax9 in forum MacReplies: 2Last Post: 14th Feb 2011, 17:40 -
Creating a short-cut icon/link to [+ Reply to Thread] in forum listings ?
By vhelp in forum FeedbackReplies: 1Last Post: 5th Jul 2010, 19:57 -
Need Help with Movie Cut Short
By shalini72 in forum Newbie / General discussionsReplies: 7Last Post: 2nd May 2010, 02:02 -
Disc name/label being cut short in Nero.
By richard_m_morales in forum Authoring (DVD)Replies: 5Last Post: 25th Sep 2008, 13:20 -
Video is being cut short.
By obite in forum Newbie / General discussionsReplies: 1Last Post: 14th May 2007, 18:39
