Hi all,
In a PAL-B country. I got a few mates with NTSC tapes. We all have NTSV playback VCR's. They can all play NTSC tapes fine on their VCR > TV setup.
Mine has NTSC playback as well. and i recall it playing fine when it was the families main VCR.
Playing it through my VCR to my PC it flickers like crazy although the VCR says NTSC on the LCD display so appears to be recognised and playing fine. So i grabbed a small 34cm TV from another room brought it into mine and layed it on there, same thing.
So borrowed a mates VCR that has played this very tape fine and guess what ...... exact same results!!
1) it flickers on mt PC
2) it flickers on the small 34cm TV
1) does a TV etc have a bearing onto how a tape is played back and therefore thats where the problem lies.
2) do i need an NTSC TV/capture card
PS i changed the jumpers on the capture card to NTSC but no difference.
PSS my VCR can play EP (Extra Long play) but the same thing results on the TV and PC, it flickers like crazy, unwatchable.
Thanx for any insight on this.
Results 1 to 9 of 9
AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
Jabber: DaveQB@jabber.org.au
2.6.29.3-desktop-1mnb -
I am also very interested to know the solution to this problem, because I have a NTSC VHS tape that I imported from the USA and I wish to capture and burn it to DVD. The VHS plays fine in my VHS recorder through the TV but not when I try to capture it via my PC. I am a very experienced video capturer and have solved all my problems apart from this particular one!
Ego -
You don't suppose it is a commercial tape with Macrovision
copy protection do you ? -
Dunno, maybe it has? Is there any software that can block the Macrovision from getting through and ruining my video capture?
Ego -
I ended up getting a semi-decent copy done using half res (352x240 or so)
it was watchable, but black and white
it was only film for scouting purposes (Football)
definately wasn't DVD like quality !AMD 64 X2 6000+ @3,000 Mhz (stock) | MSI K9N Ultra | Corsair Value/Kingston 6,144MB DDR 667 | 8800GT stock | 3710GB of storage | Powered by Mandriva 2009.1
You are probably trying to capture a PAL60 video signal.
Unfortunately not much devices accept that format for digitizing.
If you have a 878 or higher based capture card, you can try to use the
BTWINCAP driver at http://btwincap.sourceforge.net/
It supports PAL60.
I sucessfully grabbed a PAL60 signal with it... -
Thanks for the suggestion and I have downloaded those BTWINCAP drivers a few times over the last couple of years but never had the opportunity to use them, i.e. I was worried they would screw up my existing vfw drivers and maybe need a full reinstall of Windows etc.
Apparently the BT878 chipset doesn't support Macrovision, so maybe it is just a case of my VHS using PAL60 like you suggested.
Ego -
BetaMax plays fine for a while then bad picture
By LSchafroth in forum Newbie / General discussionsReplies: 7Last Post: 24th Nov 2010, 20:31 -
Video8 to DV, working fine except for one odd slightly mysterious tape
By DSMcCoy in forum RestorationReplies: 8Last Post: 13th Apr 2009, 22:35 -
DVD Plays fine on computer but is screwed up on standalones
By jalopy6 in forum Newbie / General discussionsReplies: 9Last Post: 14th Feb 2008, 08:17 -
Would a Digital Video Stabilizer work for a PAL tape in an NTSC vcr?
By ChaunceyK in forum Newbie / General discussionsReplies: 1Last Post: 21st Sep 2007, 12:42 -
VHS plays fine on TV, bad when captured...
By rachel.twu in forum Capturing and VCRReplies: 15Last Post: 9th Jun 2007, 23:38
