Hi
When I try to make a dvd with nero and other programs, it ends up with a dish for the trash can. It's files from my hdd - files that sometimes burns without problems, but more than half of them crashes. I've tried many diffrent brands of disc's - same result ;o(
My dvd-r is a lite on 411 external )USB)
Here's my nero log:
Windows XP 5.1
IA32
WinAspi: -
ahead WinASPI: File 'C:\Programmer\Ahead\Nero\Wnaspi32.dll': Ver=2.0.1.59, size=160016 bytes, created 16-12-2003 19:18:06
Nero version: 6.3.0.3
Recorder: <LITE-ON DVDRW LDW-411S> Version: FS0J - HA 2 TA 0 - 6.3.0.3
Adapter driver: <> HA 2
Drive buffer : 2048kB
Bus Type : default (0) -> ATAPI, detected: ?
CD-ROM: <QSI CDRW/DVD SBW-241>Version: VF02 - HA 1 TA 0 - 6.3.0.3
Adapter driver: <atapi> HA 1
=== Scsi-Device-Map ===
DiskPeripheral : HITACHI_DK23DA-30 atapi Port 0 ID 0 DMA: On
CdRomPeripheral : QSI CDRW/DVD SBW-241 atapi Port 1 ID 0 DMA: On
=== CDRom-Device-Map ===
QSI CDRW/DVD SBW-241 F: CDRom0
AutoRun : 1
Excluded drive IDs:
CmdQueuing : 1
CmdNotification: 2
WriteBufferSize: 32505856 (0) Byte
ShowDrvBufStat : 0
EraseSpeed : 0
BUFE : 0
Physical memory : 189MB (194032kB)
Free physical memory: 34MB (35260kB)
Memory in use : 81 %
Uncached PFiles: 0x0
Use Static Write Speed Table: 0
Use Inquiry : 1
Global Bus Type: default (0)
Check supported media : Disabled (0)
27.2.2004
UDF/ISO compilation
18:05:39 #1 Phase 112 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation started
18:05:39 #2 Phase 114 File dlgbrnst.cpp, Line 1800
DVD-Video files reallocation completed (no file modified)
18:05:39 #3 Text 0 File Isodoc.cpp, Line 6029
Iso document burn settings
Determine maximum speed : FALSE
Simulate : FALSE
Write : TRUE
Finalize CD : TRUE
Multisession : FALSE
Burning mode : DAO
Mode : 1
ISO Level : 1 (Max. of 11 = 8 + 3 char)
Character set : ISO 9660
Joliet :FALSE
Allow pathdepth more than 8 directories : FALSE
Allow more than 255 characters in path : FALSE
Write ISO9660 ;1 file extensions : TRUE
18:05:39 #4 Phase 111 File dlgbrnst.cpp, Line 1800
DVD-Video files sorted
18:05:39 #5 Text 0 File Reader.cpp, Line 118
Reader running
18:05:39 #6 Text 0 File Writer.cpp, Line 124
Writer LITE-ON DVDRW LDW-411S running
18:05:39 #7 ISO9660GEN -11 File geniso.cpp, Line 3882
First writeable address = 0 (0x00000000)
18:05:39 #8 ISO9660GEN -11 File geniso.cpp, Line 3882
18:05:39 #9 Text 0 File Burncd.cpp, Line 3101
Turn on Disc-at-once, using DVD media
18:05:39 #10 Text 0 File DlgWaitCD.cpp, Line 240
Last possible write address on media: 2297887 (510:38.37, 4488MB)
Last address to be written: 2100943 (466:52.43, 4103MB)
18:05:39 #11 Text 0 File DlgWaitCD.cpp, Line 245
Write in overburning mode: FALSE
18:05:39 #12 Text 0 File DlgWaitCD.cpp, Line 2085
Recorder: LITE-ON DVDRW LDW-411S, Media type: DVD-R
Disc Manufacturer: RITEKG - 04
Disc Application Code: 64, Disc Physical Code: 193
18:05:39 #13 Text 0 File DlgWaitCD.cpp, Line 406
>>> Protocol of DlgWaitCD activities: <<<
18:05:39 #14 Text 0 File ThreadedTransferInterface.cpp, Line 779
Setup items (after recorder preparation)
0: TRM_DATA_MODE1 (CTransferItem)
2 indices, index0 (150) not provided
original disc pos #0 + 2100944 (2100944) = #2100944/466:52.44
relocatable, disc pos for caching/writing not required/required, no patch infos
-> TRM_DATA_MODE1, 2048, config 0, wanted index0 0 blocks, length 2100944 blocks [LITE-ON DVDRW LDW-411S ]
18:05:39 #15 Text 0 File ThreadedTransferInterface.cpp, Line 948
Prepare recorder [LITE-ON DVDRW LDW-411S ] for write in CUE-sheet-DAO
DAO infos:
MCN: ""
TOCType: 0x00; Session Closed, disc fixated
Tracks 1 to 1:
1: TRM_DATA_MODE1, 2048/0x00, FilePos 0 0 4302733312, ISRC ""
DAO layout:
__Start_|____Track_|_Idx_|_RecDep_|_CtrlAdr_
0 | lead-in | 0 | 0x00 | 0x41
0 | 1 | 0 | 0x00 | 0x41
0 | 1 | 1 | 0x00 | 0x41
2100944 | lead-out | 1 | 0x00 | 0x41
18:05:40 #16 Phase 24 File dlgbrnst.cpp, Line 1800
Caching of files started
18:05:40 #17 Text 0 File Burncd.cpp, Line 4073
Cache writing successful.
18:05:40 #18 Phase 25 File dlgbrnst.cpp, Line 1800
Caching of files completed
18:05:40 #19 Phase 36 File dlgbrnst.cpp, Line 1800
Burn process started at 4x (5.520 KB/s)
18:05:40 #20 Text 0 File ThreadedTransferInterface.cpp, Line 2264
Verifying disc position of item 0 (relocatable, disc pos, no patch infos, orig at #0): write at #0
18:05:40 #21 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 13:03,425 (783425ms) -> OK
18:05:40 #22 Text 0 File DVDR.cpp, Line 1512
Recording mode: Sequential Recording Mode
18:05:40 #23 Text 0 File Mmc.cpp, Line 19487
Set BUFE: supported -> ON , SMART-BURN : ON
18:05:40 #24 Text 0 File DVDR.cpp, Line 1643
Start write address at LBA 0
DVD high compatibility mode: Yes
18:05:40 #25 Text 0 File Cdrdrv.cpp, Line 7941
---- DVD Structure: Physical Format Information (00h) ----
Layer: 0, Address: 0 (0 h), AGID: 0; Length: 2050
Book Type: DVD-R (2), Part Version: 5
Disc Size: 120 mm, Maximum Rate: <not specified> (F h)
Number of Layers: 1, Track Path: Parallel Track Path (PTP), Layer Type: recordable
Linear Density: 0,267 um/bit, Track Density: 0,74 um/track
Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
End Physical Sector Number of Data Area: 0 h
End Sector Number in Layer 0: 0 h
Data in Burst Cutting Area (BCA) does not exist
Media Specific:
00 00 00 00 00 00 00 00 - 00 00 00 00 00 00 00 00 ................
18:05:49 #26 Text 0 File Cdrdrv.cpp, Line 1277
18:05:49.305 - LITE-ON DVDRW LDW-411S\H2 T0 : Queue again later
18:06:01 #27 SCSI -500 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x03CF6000
Status: 0x02 (0x03, SCSI_ABORTED)
HA-Status 0x10 (0x0A, SCSI_HASTAT_REQUEST_SENSE_FAILED)
TA-Status 0x00 (0x00, OK)
Sense Key: 0x05 (KEY_ILLEGAL_REQUEST)
Sense Code: 0x26
Sense Qual: 0x02
CDB Data: 0x5C 0x00 0x00 0x00 0x00 0x00 0x00 0x00 0x0C 0x00 0x00 0x00
Sense Data: 0xF0 0x00 0x05 0x00 0x00 0x00 0x00 0x00
0x00 0x00 0x00 0x00 0x26 0x02
18:06:02 #28 SCSI -1114 File Cdrdrv.cpp, Line 1431
SCSI Exec, HA 2, TA 0, LUN 0, buffer 0x04390000
Status: 0x04 (0x01, SCSI_ERR)
HA-Status 0x00 (0x00, OK)
TA-Status 0x02 (0x01, SCSI_TASTATUS_CHKCOND)
Sense Key: 0x06 (KEY_UNIT_ATTENTION)
Sense Code: 0x29
Sense Qual: 0x00
CDB Data: 0x2A 0x00 0x00 0x00 0x00 0x20 0x00 0x00 0x20 0x00 0x00 0x00
Sense Data: 0x70 0x00 0x06 0x00 0x00 0x00 0x00 0x0A
0x00 0x00 0x00 0x00 0x29 0x00
18:06:02 #29 CDR -500 File Writer.cpp, Line 301
SCSI command aborted
18:06:02 #30 Text 0 File ThreadedTransfer.cpp, Line 229
all writers idle, stopping conversion
18:06:02 #31 Text 0 File ThreadedTransfer.cpp, Line 223
conversion idle, stopping reader
18:06:02 #32 Text 0 File DVDR.cpp, Line 1847
EndDAO: Last written address was 31
18:06:13 #33 Text 0 File dlgbrnst.cpp, Line 1658
Set remaining time: 0:00,000 (0ms) -> OK
18:06:14 #34 CDR -600 File WriterStatus.cpp, Line 164
Device not available
18:06:14 #35 TRANSFER -24 File WriterStatus.cpp, Line 164
Could not perform end of Disc-at-once
18:06:15 #36 Text 0 File dlgbrnst.cpp, Line 1658
18:06:15 #37 CDR -600 File WriterStatus.cpp, Line 169
18:06:15 #38 TRANSFER -39 File WriterStatus.cpp, Line 169
Could not perform EndSession
18:06:15 #39 Phase 38 File dlgbrnst.cpp, Line 1800
Burn process failed at 4x (5.520 KB/s)
Existing drivers:
File 'Drivers\atapi.sys': Ver=5.1.2600.1106 (xpsp1.020828-1920), size=86912 bytes, created 10-10-2002 23:34:02 (Adapter driver for src)
Registry Keys:
HKLM\Software\Microsoft\Windows NT\CurrentVersion\WinLogon\AllocateCDROMs : 0 (Security Option)
Thanks!
may be a problem with your burner
is where it failed-- which is either a disk error or writer error and if you tried different disks -- sounds more like a writer error ..Starting Physical Sector Number of Data Area: 30000 h (DVD-ROM, DVD-R/-RW, DVD+R/+RW)
Data in Burst Cutting Area (BCA) does not exist"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
If you can return the drive I would.
I would take the IDE drive out of the USB2 box and install the drive inside your computer. You may be having bandwidth problems with your USB2, this will eliminate that.
Try another format, you have 4 to choose from. -R and -RW don't seem to work as well as +R and +RW in the 411S drives (in my experience). -
did you use + media or -media ??
The electronic components of the power part adopted a lot of Rubycons.
