Lets forget about quality for now, but how can I put two "as orignal" DVDs onto one disc? I want to have a simple menu that comes up and says "movie A" and "movie B" after you select one, the disc plays as if it was the orignal, with menus, intro features etc....
Now I know I can use Tmpgenc DVD to take two RIPS onto the same disc (very easy tbh) but as ive said I want menus and stuff and Tmpgenc DVD does not allow this.
With DL DVDs out soon I would like to start backing up two 4.7GB films onto the once disc and again would need some type of selection menu.
I am not interested in doing DVD rips, I want full discs, obviously encoded.
Results 1 to 11 of 11
2 full movies is a LOT for a single DVDR in full res. It's cake if you re-encode them to 1/2D1. DVDShrink (re-Author, main movie only) and TMPG Author combination will do it with a simple menu. Just do a custom target size of say 2 GB each.
What you want? Hehehehe, not a chance. The full menu's will drive you nuts.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
Originally Posted by Gazorgan
then he can keep the same quality he has now and get 2 movies on one disc
as for what he was trying to accomplish, i think you are right...there isnt a way that i can see to make a menu to select movie A or B and then have it play as if it were an original DVD -
actually you can make menus using tmpgenc dvd author.
this is what i would do.
rip each movie into separate folders onto your hd. rip just the movie only.
-import each movie into tmpgenc dvd author as a separate track
-create your menus, etc.
-output the files into another folder on your hd, ignoring the message that the files are too big.
-import your files into dvdshrink and shrink to fit onto one dvd-r -
Unless I misunderstood, he is not trying to reauthor the discs but to use the original structures. This can not be done in TMPGEnc DVD Author as it can not import structure (menus in particular), only content.
Unless there is some means of doing an Autoplay-style frontend on DVD, I would doubt this could be done easily. -
Yep .... reauthoring with new front end menus to choose each movie scene selections & extras, seems to be the best compromise.
Keeping all the original menus for each movie would be a nightmare to achieve. The stucture would be untrue. -
I doubt it. All main menus are contained within VIDEO_TS.VOB for any DVD that has any extras in it. The only way you could possibly do this is with two DVDs that are movie only and only have menus in VTS_01_0.VOB.
The funny thing is, if you were really just "backing them up" you would probably just shrink the entire discs and burn them as data to a DL disc. Why would they need to be playable when you could just burn a new one from this if your original stuffed up ?If in doubt, Google it.
Comnimng Authored DVDs To One Disc
By phantomengineer in forum Authoring (DVD)Replies: 2Last Post: 7th Sep 2011, 21:23 -
full bluray disc to mkv or avchd
By Melvin18 in forum Authoring (Blu-ray)Replies: 2Last Post: 9th Apr 2010, 10:26 -
Does BD-Rebuilder Full Disc mode work?
By ronorkis in forum Blu-ray RippingReplies: 22Last Post: 1st Sep 2009, 05:12 -
BD-9 Full Disc on PS3
By teedster in forum Blu-ray RippingReplies: 4Last Post: 6th Aug 2009, 00:51 -
PAL to NTSC DVD [Full Disc] Conversion (hybrid method, very easy)
By LadyLiete in forum User guidesReplies: 28Last Post: 5th Nov 2007, 20:35
