First I want to thank all of you for the help that you’ve given me so far. I read and compare all your posts. Here’s my plan, please tell me what you think. So far I’ve gotten a LiteON DVD burner (on sale at Best Buy under the name of BUSlink). For transferring VHS & 8mm to DVD I’m going for the Canopus ADVC-100, it seems (from all I’ve read) to be about the easiest to figure out and keeps audio & video in sync. I’m going to (as your posts suggest) upgrade to Windows XP, increase my RAM to 512, and get and extra Hard Drive (around 60 gigs). Commenting on the above will be appreciated (unless you plan on confusing me more that I already am). There are still a couple of things I could use your help on. I need to get a Firewire for my Canopus ADVC-100, does it matter what kind, any recommendations? As far as software is there any that will do a good job both working with transferring VHS to DVD & Copying DVD to DVD? Do I need different software for both, and will any of this software also allow me to arrange my JPEG’s in such a way as to show them on my DVD player. Some of you have told me that there is editing software that comes with Windows XP, is that sufficient for any of the things I want done? As you can see I’m still a little confused and that’s why I’m calling on you guys.
Well Thanks again for all of your help
God Bless
Uncle Bob
Uncle Bob
There's plenty of free stuff to do what you want, but some things might be worth buying.
Capture with Movie Maker (free with XP)
Encode to mpeg2 with TMPGEnc
Author with TMPGEnc DVD Author (TMPGEnc & TMPGEnc DVD Author can be bought for under $100 - if the offer is still on)
Burn with Nero (one form or another is usually free with burners)
There are lots of other variations and you can probably do it all for free, but as all the above software has a fully functional trial period, I''d give that a go and see how you like it.
Good luck!Regards,
Rob -
new hard drive - get bigger than 60 gig... like 160 gig or so. Price difference isn't that much, but extra room will really help when working with dv-avi.
Always check helpfiles/instructions before leaping...
VHS to DVD - 3 questions (encoding & bitrate)
By spup345 in forum Capturing and VCRReplies: 21Last Post: 17th Sep 2010, 22:39 -
Interesting update for D-VHS decks on JVC site? & HM-DH4000U on sale at B&H
By OldMedia in forum RestorationReplies: 3Last Post: 4th Jun 2010, 23:20 -
Panasonic & Sony DVD/VHS recorders
By joecass in forum DVD & Blu-ray RecordersReplies: 12Last Post: 4th Dec 2008, 07:56 -
VHS To Harddrive Via S-VHS VCR & Matrox RT.X100
By westwood in forum Capturing and VCRReplies: 9Last Post: 13th Jun 2008, 09:19 -
VHS->DVD w/TBC, color going to B&W ???
By nathanaa in forum Newbie / General discussionsReplies: 2Last Post: 23rd Apr 2008, 10:34
