Hi all,
I am facing a few problems while making DVD's from home videos. My camcoder uses DV cassettes. I am capturing video through Firewire port, I am using Pinnacle to capture the video, I capture as DV AVI. Then I use DVTimeStamp to stamp date and time on the videos, after that I am using TMPGenc Plus to convert the Stamped DV AVI files to mp2 files, after this I use TMPGenc DVD Author to make VOB files and burn them to DVD's.
Now as u seen all the processes involved, I want to cut down these steps.
My ultimate goal is to make DVD's with date and time stamped on the videos, can anyone recommend a way by which I can reduce the no of steps.
Any help on this would be highly regarded.
I know it's a pain with each of these processes, but I think what you are doing is going to give you the best quality. HOWEVER! If you capture and edit in Adobe Premeire, you can export (including re-encoding) from there directly into Pinnacle Impression Pro or even SE if you don't need ac3 audio, and You're DONE! I prefer to use the TMPGEnc method, but if you're in a rush, Premeire & Pinnacle isn't that bad of a choice.
Remember when the only way to see a movie uncut was to go to the theatre?
Making a LP DVD
By zarnic in forum Authoring (DVD)Replies: 13Last Post: 11th May 2011, 07:47 -
making DVD
By narcissus in forum Authoring (DVD)Replies: 8Last Post: 19th Jul 2008, 00:18 -
making DVD
By narcissus in forum Authoring (VCD/SVCD)Replies: 2Last Post: 14th Jul 2008, 19:22 -
Need advice on making dvd copies and making ISO files please.Thanks!
By Canon GL-2 Guy in forum Newbie / General discussionsReplies: 1Last Post: 17th Jan 2008, 12:03 -
Making a DVD
By Lord Balthazar in forum Newbie / General discussionsReplies: 5Last Post: 29th Oct 2007, 08:10
