When I am converting my Avi....which is the higher quality Mpeg?
The end result will be to transfer to DVD
Peplogic
Stick with mpeg2 when burning to DVD. The higher the bitrate that you encode at the higher the quality.
Mpeg2 all the way, much more efficient than MPEG1.
I have excellant luck with converting AVI's. I do a lot of MPEG2 at 352x240 progressive, with a CQ of 2000. This is good for AVI's that are in the 300-400 MB/hour range.
Higher quality AVI's I don't do much else with. 352x480 interlaced isn't really any better than 352x240 progressive (think about it, based on a progressive source).
Only AVI's in the 1000 MB/hour range are worth the effort of converting to 704x480 (about the same thing as 720x480). These need to be 640x480 to be any good.To Be, Or, Not To Be, That, Is The Gazorgan Plan -
I'll throw in my vote for MPEG-2 also. MPEG-1 limits you to CBR and a lower bitrate. MPEG-2 is much more efficient for a given amount of disc space.
Free software to split large MPEG-PS file into many small MPEG-PS files?
By videonewbie22 in forum Newbie / General discussionsReplies: 9Last Post: 5th Jul 2018, 20:16 -
avidemux audio sync problem with MPEG-2 - alt. way to cut mpeg-2
By graysky in forum LinuxReplies: 8Last Post: 6th Nov 2011, 22:02 -
No audio when saving .MPEG file from VOB stream using MPEG Streamclip?
By Bix in forum MacReplies: 3Last Post: 25th Jul 2010, 18:12 -
Stream an MPEG file over UDP as MPEG-TS and convert back to MPEG.
By Tengil123 in forum Video Streaming DownloadingReplies: 0Last Post: 27th Nov 2009, 05:40 -
Mpeg Streamclip and Final Cut Pro .mpeg...Only 1 hour clips?
By checksum in forum MacReplies: 10Last Post: 17th Dec 2008, 00:38
