Ok for some reason when ever i extract a VCD i get the time in the cue file as 00:36:02. I am wondering how to make it where i can edit that to be the right time? I dont want to convert cause that takes to long(5minutes is to long) so is there a way to do this? I dont mind converting once to mpg but for 10 vcds now i have had to. can anyone help me? thanx
A cue file is just a text file. open it in any text editor and change the values as you see fit. I just use notepad.
You can load the bin in CDMage and have it create a new cue for you too. -
i know that but the times are messed up so i want to know how to find out what times to put in the cue file. Everything I extract looks like this
FILE "XXX.BIN" BINARY
TRACK 01 MODE2/2352
INDEX 01 00:00:00
TRACK 02 MODE2/2352
INDEX 01 00:36:02
They all have the same time so i am wondering how do i edit that cause their not burning right
Like I said let CDMage make the cue for you.
Or if this is just a standard vcd or svcd then use vcdgear to extract the mpg and then burn that instead.
<font size=-1>[ This Message was edited by: adam on 2001-07-11 18:37:55 ]</font> -
sorry i didnt read that part. i just read the part about notepad. Going to try that out. thanx.
cue and bin files
By natty in forum Newbie / General discussionsReplies: 2Last Post: 21st Jun 2011, 15:25 -
How to burn or extract some CUE or APE files?
By diets in forum AudioReplies: 3Last Post: 21st Jan 2010, 10:43 -
Having trouble with .bin/.cue files
By UncleBose in forum Software PlayingReplies: 8Last Post: 12th Jan 2008, 06:06 -
Toast error message on .cue files
By Going gray in forum MacReplies: 8Last Post: 17th Aug 2007, 12:46 -
What files/settings do I need for bin/cue
By Choppa in forum Authoring (VCD/SVCD)Replies: 9Last Post: 23rd Jun 2007, 21:29
