Hey all,
I'm experiencing a strange problem when attempting to cut an AVI using VirtualDub. I set up the mark in/mark out points as usual and proceeding to save two avi files which cut the original in half. However, for some reason when I viewed the files afterwards, the 1st AVI crossed over to where the 2nd one was supposed to start and the 2nd one contained frames that were to be at the end of the 1st AVI. So I was getting an overlap in frames, but I could see no logical reason why.
When cutting the AVI files, my first mark in point was at the beginning of the original and the end point was for arguments sake at frame 50. I saved this avi and then set the mark in point at frame 51 and the end point at 100 and saved that AVI. When I view the AVIs, AVI1 has 60 frames and AVI2 has 60 frames, not 50 like they were originally supposed to have because each has 10 frames from the counterpart AVI. (There aren't the real numbers by the way, this is just helping me to explain my problem)
Any suggestions on how to fix this or another way to go about cutting AVIs?
Mikeveli
P.S. The files encoded using a DivX codec.
AFAIK, virtualdub will only cut on I-Frames. In a divx I frames can be quite a long way apart. (several seconds). Either use the virtualdub function to advance/rewind to the nearest I-Frame when choosing your cut point, or live with it as it is.Originally Posted by mikeveli
Thanks for the reply,
Is there another program that cuts at specific frames besides having to re-encode the whole thing in something like Premiere? Also, is it possible to change the positions of the I-Frames in the DivX so that they appear on the frames I want to cut?
Mikeveli -
Not that I am aware of.Originally Posted by mikeveli
When you encode the divx, you can set the frequency of I-Frames. More I-Frames equals a bigger file (or higher bitrate required for same quality). After encode, it cannot be changed except by re-encode.Originally Posted by mikeveli
Strange problem between AVI(mpeg) file and DVD based on AVI(mpeg) file
By 1234567 in forum DVD RippingReplies: 49Last Post: 15th Feb 2009, 07:36 -
Strange audio sync problem with downloaded AVI
By embreeb in forum AudioReplies: 9Last Post: 9th Dec 2008, 08:30 -
Strange AVI Problem
By HacktheHacker in forum DVD RippingReplies: 3Last Post: 14th Apr 2008, 10:44 -
problem with cutting AVI in half with VirtualDub.
By eroy in forum EditingReplies: 1Last Post: 27th Dec 2007, 06:53 -
Strange problem converting Xvid AVI to MPG2
By joelore in forum Video ConversionReplies: 18Last Post: 1st Jun 2007, 23:40
