I have Riped A dvd an it saved the movie as a Mpg but the problem is when i went to burn it with nero it too huge iam trying to get the whole movie on too a 700mb disk i don;t want too cut it too two disk
dose any one know how i can compress this movie too fit on to a 700mb disk? Iam very new too all this![]()
best bet is to redo the movie. My questions would be what application did you use to rip and then convert. If you are planning on putting the mpeg as a VCD/CVD/SVCD or what????? If it is one of those, the size is actually 800 meg. How far over the 800 number are you?????
Well, if you want the easiest/convenient method with 'decent' quality, use DVDShrink. <---- Look just to the left on this page under HOW TO>GUIDES and do a search on DVDShrink.. just follow the guide that makes most sense to you.
Also, I strongly suggest you buy some blank DVD-R media, which holds ~4.37Gb of video/audio data (MPEG2). Putting the finished DVDShrink product onto a 700MB CD-R won't work.. You'd have to convert the MPEG2 files (DVD-compliant) to MPEG1 files (VCD and... SVCD??), which would most likely comprise video quality even more than already with DVDShrink...
Do a little reading up on this stuff b/c people might come out and start ripping on you for asking such a basic questions. good luck and ask if you've any more questions (after reading up a little, that is..
thanks guys for the replys after i posted the question i did manage to find out a bit more info like i said iam new to this may be i should just wait an get a dvd burner ...
Compress movies in Adobe Premiere the same as Windows Movie Maker
By ckeen in forum Newbie / General discussionsReplies: 4Last Post: 13th Jun 2012, 21:11 -
How do I compress a movie (12.5gb) w/o losing much quality?
By aple in forum Newbie / General discussionsReplies: 4Last Post: 22nd Jul 2011, 11:39 -
How do I convert ISO files into a movie (newbie)?
By jkundi in forum Newbie / General discussionsReplies: 19Last Post: 28th Jul 2008, 09:27 -
mpg...compress and chop
By astro604 in forum EditingReplies: 3Last Post: 1st Mar 2008, 19:50 -
Newbie problems: TS to Mpg conversion
By waehuun in forum Newbie / General discussionsReplies: 1Last Post: 8th Jan 2008, 17:00
