hi, i'm trying to get the full disk of a dvd9...i'm using clone dvd ..it reads it ok but when it start's to write it ..i run's to about 85% and stops...i tried dvd decrypter with no luck , I got a message saying there was'nt enough room on disk...any help would be appreciated...regard's theted.
You have to use DVD Shrink to compress the DVD-9 in DVD-5, then use Clone DVD to burn...You won't need to run DVD Decrypter after DVD Shrink either...
Ron -
thank's m8 for the input...u say that i dont have to run dvd decrypter..then how do i remove the protection ?..regards theted.
