Bought this puppy and so far have been satisfied with it. When thru the manuals and it's mentioned in the manual something about DTS pass thru. Does that mean I need a separate DTS decoder to get DTS out of my receiver ? I played a DTS DVD on it and I get clicks and pops out of my Denon AVR3802 Receiver. There is no DTS logo on the unit but there is on the manual.
As no one else has picked up on this, I'll have a go - though I'm no expert....
I beilieve the "pass through" means that any DVD with DTS encoding on it will be delivered to an external DTS Decoder (eg an amp, reciever or seperate pre-amp decoder) with all the information intact. The DVD player does not decode the signals itself.
I have another DVD player that does decode DTS, and that has 6 discrete outputs, one for each channel, that must then be connected to amplifiers or active speakers.
If you connect a DTS decoding amp to your player, it should, I believe, work OK. If your amp only supports Dolby Pro-Logic (as my old Yamaha amp does) you will still get Pro-Logic suround, but no DTS.
Hope this helps
Nezza -
Thanks for your reply. I have a Pioneer DVD player as well that's "retired" and it does DTS as well though it doesn't have the 5 discrete outputs. I use the optical link to connect to my receiver and it does decode it properly so not sure the decoding is done by the player or my receiver but not the philips though
and the Denon AVR3802 does do DTS.
If it has 5-outputs for speakers, this is transaltion...
"DTS Passthrough" means that you can't listen from those 5-speker outputs on that unit. It can not decode DTS but it can (I guess) Dolby Digital. It will send DTS signal through digital output without problem to your receiver where it will be decoded and sent to speakers.Pinnacle Studio 8 and DV home video editing (ver.9 already home)
DTS passthrough using AutoGK
By vdgg in forum Video ConversionReplies: 14Last Post: 21st Aug 2014, 18:03 -
How to passthrough 2 channel DTS and AC3 files?
By Phat J in forum AudioReplies: 4Last Post: 10th Jan 2012, 14:45 -
passthrough dts and ac3, reciever
By maxone71 in forum Software PlayingReplies: 1Last Post: 17th Oct 2011, 16:45 -
Philips DVDR75 overwriting existing titles
By Rletson in forum DVD & Blu-ray RecordersReplies: 4Last Post: 5th Dec 2007, 18:38 -
Philips DVDR75 worth?
By stantheman1976 in forum DVD & Blu-ray RecordersReplies: 0Last Post: 2nd Jun 2007, 12:48
