A couple posts ago, someone recommended Shareaza as a P2P. I decided to try it. The BIT TORRENT part of things work, but I can't seem to connect to the networks for edonkey. This may have to do with my firewall but is there a way around that without turning off the firewall. I can use edonkey (a little slow) with one...can I do it Shareaza...does anyone know???
Results 1 to 18 of 18
Smile
Smile -
I have never used share but you will need to open the udp and tcp ports which edonkey is trying to use.
like he said upd and tcp... especially if you running a router... emule actually has a guide to help u.. had same prob, config router left firewall alone and works fine.. emule and kazaa lite k++ is best, use nothing else
Configure those would be done through my router, or in Control Panel, or should there be a setting in the Shareaza menu. In the years that I have been using edonkey, I have always been firewalled and had slow as hell speeds. I just never really cared, until now when I can leave my work PC on ALLLL day and allll night...
Smile
Smile -
it shouldnt require anything much special .. ports 4662,4661,4665 to allow connections
try changing the ports to TCP port : 3662, UDP port: 3665 and number of connections approx 150.
see the edonkey forums for help on routers, if thats the problem.
http://forums.edonkey2000.com/phpBB/viewforum.php?f=5
Also see the help forums on overnet, as the program is basically the same:
http://forums.overnet.com/phpBBovr/viewforum.php?f=32"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
LowIDs really suck. A lot less sources, and everything generally slower.Originally Posted by beavereater
For Shareaza, there's only one port, for both UDP/TCP, for all networks. Open with your router configuration (look in your manual), usually is 192.168.x.1 or something like that.
Oh, and I only use Shareaza for G2 and occasionally ed2k, never BT, because the BT implementation is not perfect, according to Bram Cohen, the creator of BT. IMO, the best BT client is Shad0w's Experimental (current version S-5.9.9). http://bt.degreez.net
I still love Shareaza though. If you have more problems with Shareaza, try their forums, I'm there by the same name I am here (Read the FAQs first though, or you'll start being flamed like crazy). -
i went and looked and - just one port required ...
pick which one you will use in options and set firewall up same way .."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
Searh for a user on this board called "Roundabout", he is the authority on routers etc..., he talked me through my one. There is a huge thread all about ports, if I remember it is titled "port opening on a router"
Well, I have a slight disadvantage when it comes to setting things up over here. My OS is in Japanese, and I am not sure what most of this stuff means. I could ask someone for help, but most people that speak Japanese, are either computer illiterate or just can't speak good English. I will play around with the settings, thanks for the help anyway
Smile
Smile -
I thought I would give shareaza a try, but it would not import the partially downloaded files from overnet. Tries to but says it can't. Anyone know why.
There is a slightly complicated way. First you have to convert your partial Overnet DLs into eMule ones by resuming with eMule. Then, using this thread (http://forums.shareaza.com/showthread.php?s=&threadid=4413) and DonkeyDoctor (link in thread) import in Shareaza.
Another thread that should help:
http://forums.shareaza.com/showthread.php?s=32c0c24ee94595e153b5c46ed193a077&threadid=11500
I would recommend just finishing the DLs in Overnet and starting new ones in Shareaza.
How is overnet? Better performance than using eMule/non-hybrid? -
I think I will finish them off in overnet seems like too much hassle
I had problem with emule knocking out my internet connection, it would run for a while ok then it would start to freeze up the PC, on and off. So my whole system would lock up for about 10 seconds, then be useable for 10 seconds, lock up again and so on, it would continue to cycle like this and my download speed would drop down to zero then I would loose my internet connection completely. If I shut down emule the problem of freezing/thawing would persist and the only way to fix it would be to unplug my cable modem. To get back online I would plug the modem back in then goto internet connections and repair the connection.
With overnet I have no such problems and connection speeds can be very fast, upto 65-70 KB/s, but there can also be long spells of very low speeds or no speed at all.
I thought shareaza would be worth a try as it connects to more networks so there should be more sources for files. -
there is a thread here and on the shareaza forum about this and its easy to fix ... basicly use only 2 hubs , and reduce number of connections or something .... cant really remember but it works fine ....emule knocking out my internet connection, it would run for a while ok then it would start to freeze up the PC, on and off."Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
I tried reducing the number of connections, had the same problem. I don't remember anywhere you could set the number of hubs though.
That's a fix for Shareaza, right? Not eMule...Originally Posted by BJ_M
Yeah, the G2 (Gnutella2) network helps out. Sometimes I use Shareaza as a G2 only client. G1 (original Gnutella) is almost useless on Shareaza, IMO, and all you do is upload to G1, never DL.Originally Posted by Craig Tucker -
Tried shareaza but it was about as fast as an arthritic snail on my system, so I will stick to overnet which gives me very good download speeds.
Yes, a lot of people had that problem with Shareaza, but with proper configuration and just general messing around really helps. The fastest download I've ever seen is on a G2 download with Shareaza 9also fastest upload).Originally Posted by Craig Tucker
But there are a lot of improvements still to be made on Shareaza.
You should try the Shareaza forums at http;//www.shareaza.com for specific config help.
p2p DOWNLOADERS now being sued
By aedipuss in forum Newbie / General discussionsReplies: 19Last Post: 13th Jun 2010, 02:33 -
Site rip vs. torrents/p2p/etc.
By Supreme2k in forum Off topicReplies: 13Last Post: 20th Apr 2010, 23:11 -
Does Mac have any advantages over a Windows PC for P2P? Thanks.
By gary11364 in forum MacReplies: 4Last Post: 27th Apr 2008, 15:57 -
Best WIRED router for P2P? Thanks.
By gary11364 in forum ComputerReplies: 20Last Post: 18th Jan 2008, 01:40 -
Verizon Fios vs P2P
By mn072065 in forum ComputerReplies: 8Last Post: 18th Oct 2007, 07:43
