    Jan 2004
    malaysia
    anybody know there is any encoder could make DTS ES 6.1...any this kind of software ??
  2. steinberg nuendo 2 has a DTS plugin but I'm not sure if it will do 5.1 surround...I believe that may still unreachable for the public :P
    dlv
  3. Member Ste's Avatar
    Feb 2002
    Chicago
    I thought that all DTS ES 6.1 did was take a 5.1 signal and extract the center rear channel from the other 2 rear channels. I know that's what Dolby Digital EX 6.1 does:
    http://www.dolby.com/trademark/co.in.1200.MarkSurEX.pdf
    EDIT: Actually, this one is better:
    http://www.dolby.com/ht/co_br_0110_ListenersGuideEX.pdf
  4. Член BJ_M's Avatar
    Jul 2002
    Canada
  5. There is a dts 5.1 encoder, but it will set you back $5000 called Surcode. dts 6.1 Discrete is true 6.1 channels of audio, I think 6.1 ES is a matrix (ie, derived from back channels) Dolby digital has no true 6.1 and if it did would be completely uncompatible with current 5.1 decoders. dts is different and 6.1 discrete could be heard as 5.1 in a current dts decoder.
