I keep getting this error 10 seconds after I try and save/encode any file in soft encode:
Sftencdd.exe has generated errors and will be closed by windows
It's strange because I have two computers. Both, of which, it worked on for a while(different times) and then started giving me this error. Anyone else had a similar experience?
Any solutions?
Any comments?
Results 1 to 12 of 12
have you installed or changed anything on your pcs recently? did you try to uninstal and then re-instal the program? Is it just on this one audio file or all of them in general?
I'm having the same glitch. I tried re-installing it but it crashes the same way, about 10 seconds into the encode.
I haven't changed anything on my computers,no. It's weird that it's happening on both of them,exactly the same way.I have unistalled/ reinstalled and tried deleting the registry etc - I still get the same error.It's not just the one audio file, no. It happens with all audio when exporting with this software.Originally Posted by mazinz
Ok, so no one has a solution, but does anyone have any alternatives to soft encode?
why dont you get the upgrade? which is the plug in to acid/vegas ...Originally Posted by dfgh11
i believe they have a upgrade program for softencode to this"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650) -
I don't understand. You mean an upgrade for softencode so it turns into acid/vegas? or a plugin for acid/vegas? If the latter, do you mean Sony vegas?Originally Posted by BJ_M
Hi there,
I dont know if this is a solution to the problem you where having but when I was using soft encode a while back I found that certain paths crash it.
namely if I tried to encode a wav file of d:\grabbed files\test\enterprise.wav it would collapse but if I encoded a wav file of d:\enterprise.wav all was well.
May be it doesn't like deeply pathed or long filenames ...
Hope that helps
Cheers
Edz -
Ok, so I tried smaller path names etc, but it didn't work. Thanks for the suggestion though.
As for the Vegas plugin, where can I obtain this, what is it called? -
Do U have Vegas Video 4.0? If so, set up your project, then go FILE>RENDER AS and output as AC3. A dialog will pop up and you will be directed to a purchase option.
I have Sony Vegas version 4e
It is called the 5.1 Surround Plug-in Pack, don't have the exact name (not at work)
divx 2pass encode error
By ledishis in forum Video ConversionReplies: 3Last Post: 4th Apr 2012, 14:47 -
Audio encode error in MeGUI
By fatcharlie in forum Newbie / General discussionsReplies: 6Last Post: 14th Apr 2011, 11:43 -
Megui error encode !
By whitebeard in forum Blu-ray RippingReplies: 0Last Post: 17th Jan 2011, 04:46 -
RipBot264 error in MPC crashes re-encode
By gonzalu in forum Blu-ray RippingReplies: 3Last Post: 6th Apr 2009, 15:52 -
Cannot Encode, Audio Error
By kidcash in forum Video ConversionReplies: 4Last Post: 19th May 2008, 02:18
