Can this be done?
I tried putting it in my mac but it doesn't recognize it.
I figured I could just run it thru dvd backup but it ain't gonna be that easy, is it?
I have 2 2-dvd sets purchased in England that I wanna be able to watch on my regular setup.
Thanks for your help!
This is a commercially pressed DVD movie, and the Mac doesn't even mount the disc? Please confirm if this is the case. If so, I'd suggest either cleaning or replacing your DVD drive, as yours must be defective. If you're still under warranty, get it fixed by whoever sold you that drive (Apple, in most cases, unless you installed your own). Since you say (in your computer details) that you have a G3 600 running OS 9.2.2, I'm gonna guess you're not covered by warranty, and that you have an iBook, and that you should check out what kind of 3rd party iBook drive upgrades might be available, or buy yourself an external FireWire DVD-ROM drive (~$50-$60), and you can even get region-free firmware for many models, to facilitate multi-region playback and ripping on your computer.
I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
I restarted and it played fine in my mac.
Now that I look at it more closely the region is 0 but it is a PAL dvd.
Is there a way to go from PAL to NTSC? -
I had the same problem, the most recent version "mpeg2 works" has a nifty little app that is bundled along with it called "DVD converter" which will convert PAL to NSTC and the other way around, video along with audio. and it works great, and very easy two or three click and BAM! you have a 4 hour wait......
Ripping Region 1 disc to burn Region 2/Free ?
By Alan Rouge in forum DVD RippingReplies: 7Last Post: 28th Sep 2010, 22:09 -
Error backing up brand new disc
By pugvader in forum Newbie / General discussionsReplies: 3Last Post: 25th Jan 2009, 19:25 -
Arghhhhh backing up a KARAOKE CD+G disc
By the-doctor in forum Newbie / General discussionsReplies: 3Last Post: 24th Mar 2008, 23:06 -
Region1 disc... need to backup to region 0
By snadge in forum DVD RippingReplies: 11Last Post: 1st Mar 2008, 14:25 -
Backing up Region 3 DVD
By javajeep in forum DVD RippingReplies: 5Last Post: 29th Jan 2008, 00:55
