greetings people!
first of all, thank you guys for this excellent forum and of course a special thank you to Chrissyboy for an outstanding program!
now to my question..
everything is working perfectly with the movies and the menue.
though I can see the menue for about 4 sec and then the movie starts playing automatically.
I don't want this to be automatic, I want to be able to decide when to start the movie, by pressing the button by myself.
if this isn't possible, is there a way to at least increase the time, before a movie starts playing automatically?
ps: it is not a problem on my PC.
thanx in advance.
/ svcd2dvd -addict
Results 1 to 9 of 9
to keep in mind..
I use the latest registered version of the program and also been using the, 120 frames encoding setting and still I think the menue disappears to fast. (about 3-4 sec)
Chrissyboy, any suggestions? -
What is your player?
This may help you:
https://www.videohelp.com/forum/viewtopic.php?p=810849#810849
CBSVCD2DVD v2.5, AVI/MPEG/HDTV/AviSynth/h264->DVD, PAL->NTSC conversion.
ok, thanx a bunch!
IŽll try that out, and let you know my results..
by the way, I have a "Philips 752" -dvd player. -
hi ChrissyBoy!
I've tried changing the value to 1800, but I still get the same results. the menue disappears to fast. (about 3-4 sec).
in your post, on Feb 13, 2004 12:25 you wrote as follows;
"Well increasing the number of frames would only delay the "pause". 120 frames is about 4 seconds. so you would need to think about the duration that would be acceptable.....
Anyway, here is something you can try:
you can change the value (in your registry) of:
HKEY_CURRENT_USER\Software\Badgersoft\DVD MenuMaker\EncodeSize
to a custom value. The # is the number of frames. remember that in PAL you have 25 frames per second and in NTSC you have 29.997 frames per second.... so you can work out your required frames for a given duration.
Also if your duration is over 5 seconds then the menu will loop. This also may get you to where you need to be.
(the above value will only be used by DVDMM if it can encode in a certain way. Some OS's can't so it encodes another way and this value will not be used. If this is the case i will make a code change so that it does....)
I suspect this Blur effect is an attribute of your player (does this happen on the PC?). If this is the case i too would be interested to see what another menu program would do differently.....
Sorry about the delay....."
so, I was thinking maybe DVDMM can't encode in this certain way, in my case..
what to do, any suggestions?
PS: I have,
Microsoft Windows XP Professional version 2002 with Service Pack 1.
/Babbage -
hi again ChrissyBoy!
I didn't get an answer for my last post here, so I'm giving it a try again.
thanx in advance.
/ Babbage -
I have changed the way menus are created (under the hood), in v2. I shall put together some menus for you to test to see if this problem is resolved for you in the up and coming version.
MeGUI queue pausing for no reason
By The111 in forum Newbie / General discussionsReplies: 0Last Post: 19th Mar 2009, 20:29 -
pausing between chapters
By rich73 in forum Newbie / General discussionsReplies: 1Last Post: 3rd Mar 2009, 06:50 -
main menue & submenue are not working properly with GFD
By akakiami in forum Authoring (DVD)Replies: 1Last Post: 29th Sep 2008, 07:14 -
DVD Pausing automatically (when I don't want it to)?
By rootyb in forum Authoring (DVD)Replies: 4Last Post: 31st May 2008, 11:08 -
How to insert a video in a DVD that have menue without re-processing all?
By whenloverageswild in forum EditingReplies: 0Last Post: 26th May 2008, 08:47
