  1. I believe I am having problems with some Memorex DVD+r's
    I have tried to backup one of my DVD's and have used two different methods, both unsuccessful. First I tried to copy the whole DVD with DVDxcopy platinum (advanced mode), and produced an unreadable disk (by both DVD player toshiba sd-1800, and computer LG 4040B).
    I then used the newest DVDShrink to backup just the main title, and burned with the writing utility provided with TMPGenc DVD Author. Again I recieved a wholly unreadable disk with the same media (and an error "invalid allocation unit...at end of burning)
    However using method 2, DVDShrink main title, I succesfully burned with a Maxell DVD-RW (RICOHJPNW11) .
    I have to be sure, so if you are sure what is causing this problem, help would be very much appreciated.
  2. as you stated its the CMC dye, do a search on this forum, for Memorex CMC and youll find out there pretty poor quality.
  3. ok, thanks, I did and it is pretty obvious the CMC's are lower quality (the misconceptions sticky) and that is my problem. Thanks for your reply
  4. I have no problem with CMC Memorex DVD+R 4X, burned over 25 of them and not one coaster, played well with my APEX 1500 standalone. BTW using DVD Shrink + Nero and DVDXcopy
  5. AVPM..what dvd burner did you use.
    Thanks for the input
  6. I have no problem burning these memorex cmc's with dvd decrypter at
    2.4x.
  7. I have had no problems with the Memorex DVD+R CMC MAG-F01's. No problems meaning out of 100, I didn't have an unreadable disc. I can't say about compatablity with other players besides a Playstation, my Cyberhome stand alone dvd player, or my TDK 420N.
    I am using a TDK 420N burner. I backup the main movie using DVD Shrink, I then use Imgtool to make the image and then DVD Decryptor to burn at 2.4x. The discs do say 4x, but aren't recognized as such by my burner.
    I got 100 from Best Buy in January (or around that time) when they were on sale.
