  1. I used that tmpengc to convert to Mpeg but when i try to use easy cd creator 5 platinum it says not correct format. What do i have to do to put my dvd on a disk? Any help is appreciated.
    Jason
    Sep 2001
    Swampfoot, Florida
    Newbe here too.
    For vidio to work correctly in a DVD\VCD player it hase to fit some very strict standards.
    For VCD it must be 352x240 and 1150kb/sec audio = 224
    EZ CD is not tollerent of non standard formats.....
    I'm still learning the quirks.
  3. Get Nero instead, best burner software out there.
  4. Member holistic's Avatar
    May 2001
    here & there
    "What do i have to do to put my dvd on a disk?"
    DVD ? I hope you mean VCD
    convert to what ? mpeg1/2
    DVD will require DVD authoring app.
    Have not used EZCD-5 (use NERO) but does it not have a 'selection' for non standard burns (requires EZCD users to answer this 1)
