I have just finished a block at college which showed us how to capture video from a VCR using Adobe Premiere and a vid capture card (which at home i do not have).
I am planning to put all my favourite Simpson cartoons on VCDs using Premiere. How would i go about this and what hardware and extra software would i require.
Martyn Bissett
www.martynbissett.co.uk -
Weren't you just taught that?
You've already answered your own question in your message. The only difference is that many capture cards come with their own software. -
You just need a reasonably fast system and a video capture card. The WinTV-Go works okay for me. As for capturing software, you can use AVI_IO (trialware) or VirtualDub (freeware), both of which will probably work much better than Premiere. For encoding to MPEG-1 for the VCD, I suggest using TMPGEnc.
If you need any help with your cartoon captures, you might want to check out my video guide:
http://www.geocities.com/lukesvideo/index.html
-Cart
http://www.geocities.com/lukesvideo/index.html -
On 2001-07-12 04:47:11, Cart Wheel wrote:
You just need a reasonably fast system and a video capture card. <snip> As for capturing software, you can use AVI_IO (trialware) or VirtualDub <snip>
</BLOCKQUOTE></FONT></TD></TR><TR><TD><HR size=1 color=black></TD></TR></TABLE>
My experience: I have a PII 350 and cannot use AVI_IO or VirtualDub because the video buffers fill up almost instantly. However, I can capture all I want with no dropped frames at VCD resolution if I use the software that came with my Pinnacle capture card.
BTW, visit alt.binaries.tv.simpsons and snag one of the excellent "VCD by 'O'" posts. Incredible quality for a VCD. Too bad his old ones are repeats ... -
Craig,
That sounds like a case of poor drivers. There's no reason why a card shouldn't work just as well in AVI_IO/VirtualDub as in other programs. The drivers are probably using a VFW -> WDM wrapper. Have you tried upgrading to the latest version of the capture drivers, preferably with true VFW capture support?
I'd check out one of those VCDs, by there's a post missing from my new server. Oh well.
-Cart
Equipment & Software Required To Host And Stream Live Video To Web
By wet bimbette in forum Video Streaming DownloadingReplies: 0Last Post: 26th Nov 2011, 05:18 -
DVD-Video Audio Spec. (Dolby 2.0) vs. Blu-Ray Disc Audio Spec. (Dolby 2.0)
By Disco Makberto in forum AudioReplies: 5Last Post: 31st May 2008, 15:30 -
best video capturing software?
By majax79 in forum Newbie / General discussionsReplies: 3Last Post: 3rd Jan 2008, 16:40 -
Help Required. Capturing DV to PC
By jeffbhoy in forum Newbie / General discussionsReplies: 10Last Post: 21st Jun 2007, 19:37 -
Software Required
By dbanga in forum ProgrammingReplies: 2Last Post: 15th Jun 2007, 07:47
