Hi all
I have a weird problem i burned a dvd -r some days ago and worked fine on my standalone, but today i want to watch it agian and my dvdplayer say no disk.
what could be the problem here.?
this is the first time this happend.
I hope somebody can help me out..
hey reynaldo..need more info please..such as what was it that your burned, type of media, type of set top player..and type of authoring software..thanks..
fifer55 -
Hi - I had a similar thing happen, and it was down to cheap media. I've also had cd-r's do the same thing - I'll burn a copy of a cd for the car, and in a week or two the cd starts skipping or won't even play at all.
Try different media... One thing I've found on the DVD+RW's I'm using at the moment, as well, is to perform a full format before use rather than a quick erase...
"Ramblin'" Wc -
What is the size of the file on your DVD-R? My DVD-player won't play DVDs with less than 1GB of data and DVD-RWs with less than 4GB of data. To get to these level, I copy some .avi files in the audio_ts subfolder which is so far of no use.
I burn with nero 5.5.10.15 enterprise edition , casue the the latest version doenst work for meOriginally Posted by fifer55
and i used princo 4x
My dvdplayer is a sony and author program Dvd LAb.
i always use the princo 4x first i had the 2x but those where f...ked up.
i hope you can helpme out
Standalone player will not play DVD
By Chala in forum Newbie / General discussionsReplies: 12Last Post: 16th Sep 2010, 04:09 -
DVD doesn't play in standalone player
By descotes in forum Newbie / General discussionsReplies: 9Last Post: 8th Jul 2009, 23:57 -
Why can I not burn DVDs that play in my standalone DVD player?
By bmoreravyns in forum Authoring (DVD)Replies: 12Last Post: 18th Sep 2008, 15:05 -
DVD Doesnt Play Correctly On Stand-alone Player! (Skips)
By Ace-Of-Spades in forum Newbie / General discussionsReplies: 16Last Post: 12th Sep 2008, 20:07 -
Why doesnt DVD play on mac/PS3/dvd player
By chronic777 in forum Newbie / General discussionsReplies: 2Last Post: 12th Aug 2007, 14:06
