Sorry for this newbie-question.
I have some .vob-files I want edit in FCP.
Is it possible to do this with ffmpegX. This is the only program I found which can convert my .vob-files, so it seems to me like I have to find a way to do this with ffmpegX.
THX for your help.
P.S. Sorry, my english is not that good
vobconverterGuest
modernhomesGuest
I am encountering a problem importing mov from divx doctor into fcp when I encode individual vob files
When encoding all vob's from one film into avi (ffmpegx)and then using divx doctor to make an mov I get something that that fcp likes.
However I have dvd's that ffmpegx that appears not able to encode the vobs as one file. The issue is when I encode individual vobs into avi and then produce mov's with divx doctor, fcp only imports the first mov made from the first vob and refuses the subsequent files.
Does anyone have a solution?
Hi,
I have just done it with MacMPEG2Decoder. Saved video as QT .mov using the Animation Codec (because it was a short clip). Converted Audio on the same .vob with FFMpegX using the preset MP3(film). But I thin the sound would be better in AIFF using another program on a demuxed file (for instance with MacAC3Decode).
modernhomesGuest
Thankyou for responding to my posting, but what I really want to know is why ffmpegx will on occasion refuse to encode all .vob files from a video TS folder?
And,
Why, when I encode individual .vob files which are then fed into divx doctor to produce mov. files with uncompressed audio, FCP will import the first .mov from the dvd, but refuses to import the 2nd and 3rd etc.?
Does anyone have specific answers to these questions?
Help! How to convert mpeg-2 file with LPCM audio to Final Cut Pro?
By afireinside181 in forum Video ConversionReplies: 3Last Post: 31st Oct 2011, 18:59 -
Issues Editing Skype's .MOV's in Final Cut Pro.
By macphoto in forum EditingReplies: 1Last Post: 14th Sep 2011, 20:18 -
Best file type to convert .trp for Final Cut editing
By kmxe in forum Video ConversionReplies: 2Last Post: 25th Oct 2010, 12:26 -
VOBs convert to what? to edit in final cut pro...
By tSu in forum EditingReplies: 4Last Post: 16th Nov 2007, 22:07 -
final cut express and final cut pro 6
By ednarophati in forum MacReplies: 1Last Post: 16th Jul 2007, 10:05
