I have an I/O 8x burner, TDK-R and Liquidvideo+R, adobe encore, dvd decrypter, TMPGEnc dvd. set top players are Pioneer DVD 414, Initial IDM1731, Panasonic A310. I have made discs that play in some but not all the players with various combo's of the mentioned media/tools. I checked the player compatibility page and all players should go + or -.
Seems the dvd's made with Adobe Encore work in the Initial but no others...and those made with dvd decrypter or TMPGEnc work on all but the initial. Any ideas? is there a cure all? I need the kid movie backups to work in the car (initial) and in the living room without multiple copies of each movie...
try slowing your burn speed to minimum allowed by your media brand/type.
if no luck, perhaps a change of media brand... ritek G04's are highly regarded.Always check helpfiles/instructions before leaping... -
I slowed down to 2x and now can't finish a burn. Looking at 4 coasters! Man, things were going so smooth, I knew it had to end. I will try 1x...
thanks
Problem playing wmv files in Windows Media Player and Media Player Classic.
By rayden54 in forum Software PlayingReplies: 4Last Post: 1st Aug 2008, 23:49 -
media server software to stream to my HTPC, What software works the best to
By onedeviantd in forum Media Center PC / MediaCentersReplies: 1Last Post: 27th Feb 2008, 22:45 -
Video not visible in editing software/visible in Media Player
By kb1985 in forum Newbie / General discussionsReplies: 1Last Post: 1st Aug 2007, 19:21 -
how do I flip an AVI video in windows media player or media player classi
By mdavenport in forum Newbie / General discussionsReplies: 2Last Post: 6th Jul 2007, 00:18 -
DVD Audio Plays On DVD Software But Not On Windows Media Player 11
By CurtisMinBC in forum AudioReplies: 2Last Post: 29th Jun 2007, 13:39
