I make SVCD compatible files using TMPGEnc and then use SVCD2DVD to create a DVD containing one or more 'movies' (usually two). Often the TMPGEnc 'source' files are on a networked PC I use drive mapping to make the directories appear local. The final VOB files are stored locally space permitting. Network is 100Mbps, PCs are midrange IBM P3s, OS is XP-pro.
I've noticed that the demuxing phase takes about 10 minutes per GB - which is OK by me - but the subsequent muxing phase which produces the movie-DVD.mpg file takes about 100 minutes per GB. During this phase network utilisation is about 5% and CPU utilisation is under 50%. Doing the numbers for 2 2GB movies it takes 20+200+20+200 [7+ hours] to create the movie1-DVD.mpg and movie2_DVD.mpg files, add about another 2 hours to create the [local] VOB files and another 1/2 hour for the DVD burn and verify and the whole process of turning two SVCD compatible mpeg files into a SVCD-on-DVD takes about 10 hours.
Given I prefer to use a network at some stage during the tmpgenc.mpg > SVCD process can anyone advice me how to speed up the work.
Locally it takes about 30 mins. Why are you networking?
Originally Posted by ChrissyBoy
I have been thinking about this problem for a while, and the only reason I could come up with would be that this person maybe has uncompressed AVI on the other machine, and no room for that on his own.
Callan
Can't use one of my XP pc's on network (Network experts)
By neworldman in forum ComputerReplies: 5Last Post: 21st Jan 2011, 15:12 -
Very poor performance on ATi 650 USB PLZ HELP
By Marto2008 in forum Capturing and VCRReplies: 12Last Post: 16th Jun 2010, 18:54 -
Poor VHS or Poor VCR?
By ryangarfield in forum RestorationReplies: 10Last Post: 7th Jun 2010, 06:34 -
Network printer on separate network?
By Lucifers_Ghost in forum ComputerReplies: 7Last Post: 5th Dec 2008, 13:52 -
Still Performance
By crocker5731 in forum Camcorders (DV/HDV/AVCHD/HD)Replies: 5Last Post: 5th Dec 2007, 10:31
