Anyone know how I can add a water mark to my videos?
[useless unfunny joke]
Oh, that didn't help? Maybe google can help...
[Edit] Removed useless comment [/Edit]I like systems, their application excepted. (George Sand, translated from French), "J'aime beaucoup les systèmes, le cas d'application excepté." -
Assuming you mean a semi transparent logo like image like those seen on the major networks and cable stations (usually sitting in the lower right corner of the screen), you can get this effect with either Final Cut Pro, Final Cut Express or iMovie. You need to create an alpha channel mask (in Photoshop or similar software; the open source GIMP will do this also). Then in the video editing app of choice you will load the masked image as a track. Depending on the application you can change the opacity, color.
In other words it's a still image that is mapped to every frame of the film. Usually the image is mono colored and semi tansparent so the image benath shows through. If the logo is only made of text, you can possibly do it in Livetype, or possible iMovie's title tool (though I've not tried it). For example, you could crerate a title that reads HBO and have it appear in the lower corner and fade the type via a mask.
william -
I agree. Final Cut would be the easiest way to do this. Save out a .psd file and you can place it where you want in the video track and it'll be there for the entire length.
I have SONY Vegas Studio 4 and want to add a water mark on my video. Is there any way it can be done? I'm not a MAC person...
vcdlover -
Yeah, probably.Originally Posted by vcdloverIf it isn't broken, take it apart and find out why.
blog: deadsierra -
Hi! I know the program that can add not only watermark but logo to video too.You can download it fromOriginally Posted by JoeRodr
xxxxxxxx
You can add the watermark as a simple composite if you bring it in from Photoshop with an alpha channel. This will work in most NLEs.
If you happen to have Compressor, you can add the watermark at transcode time and save the rendering/duplication in your editor.
it's also possible to add a watermark as a subtitle image in DVD Studio Pro, but the capabilities are more linited."PC-Free" since 1988...
Dual 2.5GHz G5 PowerMac/5GB/1TB internal RAID/dual monitors and a bunch of G4s.
How to add watermark? Please help
By lana in forum Newbie / General discussionsReplies: 2Last Post: 2nd Dec 2010, 05:18 -
The easiest and faster way to add a watermark in my video
By morsino in forum Video ConversionReplies: 9Last Post: 10th Jul 2010, 09:51 -
Add Watermark To Video?
By johngomez0468 in forum SubtitleReplies: 5Last Post: 29th Jan 2008, 17:48 -
How to add watermark to a video with mencoder or how to scale with FFmpeg?
By ApplePro in forum Video ConversionReplies: 16Last Post: 21st Nov 2007, 10:12 -
How to Add a Watermark to the whole video file?
By mbextreme in forum Authoring (DVD)Replies: 12Last Post: 14th Oct 2007, 16:21
