I have a media file(s) consisting of the following extensions:
nameoffile.avi
nameoffile.idx
nameoffile.sub
Where the nameoffile.avi is the main file.
Gspot tells me that the video format is Xvid, and the audio codec is AC3filter.
The nameoffile.avi plays in WMP ok, but the audio is quite low, and when I converted it to mpg, dvd compliant file, there was no audio at all.
I tried to extract the audio using Virtualmoddub, but it gave me an error saying it could not locate decompressor for XVID.
Ok so what codecs do I need now?
Bob Heselwood
u should have the xvid codec and ac3 filter which may also fix the audio level for u, but ur video has a subtitle file with it, do u need these? id use ffdshow for this then, if ur trying to convert to mpg with tmpgenc decompress the audio with virtual dub, by loading the video and setting to direct stream copy in the video menu, then set in the audio menu to full processing mode, and again in that menu under compression set it to none then just hit save as avi in the file menu , some people prefer to extract a wav file instead, but this works for me
When I try to save the nameoffile.avi to avi, after following your advice as to how or what to do, I get an error message telling me it could not find
the audio decompresor to compress the source audio format, but I am not trying to compress it...doing it as you say.
Oh for some unknown reason, after downloading the AC3filter.exe file, I cannot run it to set bit up. The exe file just opens and closes immediately!
ThanksBob Heselwood
SYNC PROBLEM: X264 AC3/DTS MKV --->>> Xvid with VBR mp3?
By Randm in forum Video ConversionReplies: 6Last Post: 30th Jul 2013, 18:57 -
Xvid AC3 file playback problem on Standalone DVD player
By kamol88 in forum Video ConversionReplies: 2Last Post: 21st Mar 2009, 04:38 -
How to convert AVI/DivX/XviD with AC3 to DVD with AC3
By Baldrick in forum User guidesReplies: 52Last Post: 21st May 2008, 20:22 -
XVID AC3 TO MP3 Conversion problem help!
By sere83 in forum Video ConversionReplies: 4Last Post: 3rd Nov 2007, 15:55 -
xvid.ac3-waf-avi convert problem?
By ptr866 in forum Video ConversionReplies: 3Last Post: 6th May 2007, 10:06
