I have ripped a home DVD to a quicktime mp4 file. I was wanting to edit in iMovie 4, but the file is over the 2GB limit for individual clips. Is there a program that can split the file in to smaller pieces other than QT Pro. Thanks in advance!
Other than QT Pro, which would be the easiest way.
Adobe Premire
Final Cut Pro
FInal CUt Express -
You can break DV files to smaller <2G segments iMovie can import with these handy AppleScripts:
http://www.danslagle.com/mac/iMovie/tips_tricks/6003.shtml -
i hope this is related. (my first post) mpeg2works allows you to split files in half or to fit a cd or dvd, buy how do i trim mpegs. i converted a VOB to MPG and want to split it as it contains 2 short films and quicktime pro won't let me do it. this is driving me crazy because there is probably a simple answer. thanks in advance for any help!
Problems importing Quicktime movies into Sony Vegas
By matthewjohn23 in forum Newbie / General discussionsReplies: 8Last Post: 11th Feb 2011, 21:31 -
Error 2048 Quicktime Problem (Home Movies)
By cliffm10 in forum Software PlayingReplies: 0Last Post: 19th Apr 2010, 12:06 -
splitting movies problem
By scarlac in forum Newbie / General discussionsReplies: 2Last Post: 25th Mar 2009, 03:24 -
Joining Image and Two Separate QuickTime Movies
By lindylex in forum EditingReplies: 2Last Post: 13th Mar 2008, 13:30 -
any quicktime movies go green
By matneaves in forum Software PlayingReplies: 4Last Post: 5th Aug 2007, 16:00
