I want to use whatever kind of software is needed and make system restore/recovery discs from my current setup, just like the ones Compaq made for my system.
But it must be for DVD media, not CD media. Nero 5.5 has a "Backup HD" function, but requires CDs. It's either 15-20 DVDs or 125-150 CDs (yuck!) to do the job. I'd rather do the DVD method.
Something surely exists... any ideas? Help! Thanks.
One system is a Windows ME system. The other runs Windows XP Pro.
The ME system is most imporant. I can redo the XP one if needed.
Results 1 to 9 of 9
Image software
ghost burns straight to DVDs
Backup software
Veritas
NovaBackup
What I do,
I create a ghost image of my primary HDD once a month on DVD-RWs
I keep them for 6 months and then write over
I do backups to tape once a week of my data storage area, as I store all data to a specific partition -
Veritas NovaBackup ?
If my HD dies one day, can the restore discs do like the Compaq ones, and reformat, repartition and fully restore the hard drive contents?Want my help? Ask here! (not via PM!)
Veritas = http://www.veritas.com/index.jhtmlOriginally Posted by lordsmurf
NovaBackup = http://www.novastor.com/
If you want a simple restore disk like an OEM, I would suggest using
http://www.symantec.com/ghost/
or
http://www.powerquest.com/driveimage/ -
I use DriveImage. It's by the same guys that make Partition Magic (PowerQuest). It will make images on dvd and has a "boot restore" feature - but to be honest, I've never actually done the boot thing.
oops, stiltman beat me to it! -
@ Mr. Smurf
So??? -
I'm looking at both things right now, Norton Ghost and then DriveImage. Norton has tutorials online that show exactly what I want, so I'm leaning that direction right now. No decisions yet.
Use Ghost. Its so simple and gets the job done right. Its always worth doing a Ghost image before installing any new software, as its easier to re-ghost a hard drive than completely remove some fucked-up code!
System Restore
By tcory in forum ComputerReplies: 10Last Post: 21st Dec 2010, 03:13 -
System Restore oddity!
By Soixante in forum ComputerReplies: 2Last Post: 9th Sep 2010, 13:46 -
Space used by System Restore?
By bevills1 in forum ComputerReplies: 5Last Post: 3rd Jan 2010, 11:12 -
system restore problem
By Willy5157 in forum ComputerReplies: 2Last Post: 11th Oct 2009, 18:46 -
What does it mean? Create a system restore.
By alintatoc in forum ComputerReplies: 4Last Post: 24th Mar 2009, 05:41
