Hello
I, an incompetent, am trying to create a standard 4GB DVD from a DIVX scource. The material works in VLC. I have studiously read the very clear manual and have setup the parametres accordingly. But get the magic 30sec file creation that is invisible at its destination. I offer the following code. (My installation of the various components was accepted only after I had created a password in my user settings, which was not the case before installation.)
Can anybody look at this and tell what I did wrong?
INFO: [yuvscaler] yuvscaler (version 1.7.0) is a general scaling utility for yuv frames
Thu Feb 26 20:00:49 CET 2004
INFO: [yuvscaler] (C) 2001-2002 Xavier Biquard <xbiquard@free.fr>
INFO: [yuvscaler] yuvscaler -h for help, or man yuvscaler
/bin/sh: /usr/bin/mpeg2enc: cannot execute binary file
## Component Manager: attempting to find symbols in a component alias of type (regR/carP/x!bt)
++ WARN: [yuvscaler] Could not infer norm (PAL/SECAM or NTSC) from input data (frame size=720x480, frame rate=24000:1001 fps)!!
INFO: [yuvscaler] input: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] input: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] input: interlace: none/progressive
INFO: [yuvscaler] input: sample aspect ratio: 1:1
INFO: [yuvscaler] from 720x480, take 720x480+0+0, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] scale to 720x480, 720x480 being displayed, NOT_INTERLACED/PROGRESSIVE
INFO: [yuvscaler] Scaling uses the RESAMPLE algorithm,
INFO: [yuvscaler] without line switching
INFO: [yuvscaler] without time forwarding
INFO: [yuvscaler] Without luminance correction
INFO: [yuvscaler] Without chrominance correction
INFO: [yuvscaler] frame rate: 23.976 fps
INFO: [yuvscaler] Scaling ratio for width is 1 to 1
INFO: [yuvscaler] and is 1 to 1 for height
INFO: [yuvscaler] Specific downscaling routing number 4
Results 1 to 9 of 9
happy69Guest
I redownloaded the files that appear as code in explorer. I copied the code to a txt file and reinstalled both the code and ffmeg. THe installer was happy, but when I try to covert a DIVX to DVD, I get the lignting fast, invisible file result.
Also, when using material that is not TV ratio do I choose a ratio that corresponds in your list and expect to have the bars appear or do reconvert back to 4:3 to then have the TV shrink the image (DVD on TV naturally)
Lastly, I don't know how you do this code stuff but I find it admirable. Thank you
Fri Feb 27 08:27:50 CET 2004
help69Guest
Thank you. It did the trick (eventually)
Now for more problems. I launched a divx to DVD conversion and it was going very well until the last minute when it failed. The result is that I have 3 files that are the result of the marathon 8 hour encoding.
2 of them are standard .mpg files that In QT easily. The first is 1.9GB and has 90% of the audio, the 2nd is the last 10%. Both have encoded audio and work fine. The 3rd is a m2v file of the complete program but is mute which reluctantly opens in QT.
The hope was to have a muxed DVD all ready to burn, so what went wrong and do I have to start again?
Encoding started on Sat Feb 28 12:51:08 CET 2004
INFO: [yuvscaler] output: frame size: 720x480 pixels (518400 bytes)
INFO: [yuvscaler] output: frame rate: 24000/1001 fps (~23.976024)
INFO: [yuvscaler] output: interlace: none/progressive
INFO: [yuvscaler] output: sample aspect ratio: 1:1
INFO: [mpeg2enc] Selecting DVD output profile
INFO: [mpeg2enc] Assuming norm NTSC
INFO: [mpeg2enc] Encoding MPEG-2 video to /Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken.m2v
INFO: [mpeg2enc] Horizontal size: 720 pel
INFO: [mpeg2enc] Vertical size: 480 pel
INFO: [mpeg2enc] Aspect ratio code: 3 = 16:9 display
INFO: [mpeg2enc] Frame rate code: 1 = 24000.0/1001.0 (NTSC 3:2 pulldown converted FILM)
INFO: [mpeg2enc] Bitrate: 5855 KBit/s
INFO: [mpeg2enc] Quality factor: 5 (Quantisation = 5) (1=best, 31=worst)
INFO: [mpeg2enc] Field order for input: none/progressive
INFO: [mpeg2enc] New Sequence every 4000 Mbytes
INFO: [mpeg2enc] Assuming non-video stream of 246 Kbps
INFO: [mpeg2enc] Search radius: 16
INFO: [mpeg2enc] GOP SIZE RANGE 9 TO 15
INFO: [mpeg2enc] Setting colour/gamma parameters to "NTSC"
INFO: [mpeg2enc] Progressive format frames = 1
INFO: [mpeg2enc] Using default unmodified quantization matrices
INFO: [mpeg2enc] Buffering 39 frames
INFO: [mpeg2enc] SETTING AltiVec for QUANTIZER!
INFO: [mpeg2enc] SETTING AltiVec for MOTION!
INFO: [mpeg2enc] SETTING AltiVec for TRANSFORM!
INFO: [mpeg2enc] SETTING AltiVec for PREDICTION!
INFO: [yuvscaler] Couldn't read FRAME header: bad header magic!
**ERROR: [yuvscaler] Couldn't read frame number 119979!
INFO: [mpeg2enc] Guesstimated final muxed size = 2184828332
INFO: Opened WAV file, freq = 48000 Hz, channels = 2, bits = 16
INFO: format = 0x1, audio length = 960611328 bytes
INFO: slots/frame = 672
INFO: frac SpF=0.000, tot bitrate=224 kbps, s freq=48.0 kHz
INFO: System is big endian
INFO: Avg slots/frame = Inf; b/smp = Inf; br = Inf kbps
INFO: Encoding with psychoacoustic model 2 is finished
INFO: The MPEG encoded output file name is "/Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken.mp2"
INFO: [mplex] mplex version 2.2.2 ($Date: 2003/05/13 20:27:15 $)
INFO: [mplex] File /Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken.m2v looks like an MPEG Video stream.
INFO: [mplex] File /Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken.mp2 looks like an MPEG Audio stream.
INFO: [mplex] Video stream 0: profile 8 selected - ignoring non-standard options!
INFO: [mplex] Found 1 audio streams and 1 video streams
INFO: [mplex] Selecting dvdauthor DVD output profile
INFO: [mplex] Multiplexing video program stream!
INFO: [mplex] Scanning for header info: Video stream e0 (/Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken.m2v)
INFO: [mplex] VIDEO STREAM: e0
INFO: [mplex] Frame width : 720
INFO: [mplex] Frame height : 480
INFO: [mplex] Aspect ratio : 16:9 display
INFO: [mplex] Picture rate : 23.976 frames/sec
INFO: [mplex] Bit rate : 5855200 bits/sec
INFO: [mplex] Vbv buffer size : 229376 bytes
INFO: [mplex] CSPF : 0
INFO: [mplex] Scanning for header info: Audio stream c0 (/Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken.mp2)
INFO: [mplex] MPEG AUDIO STREAM: c0
INFO: [mplex] Audio version : 1.0
INFO: [mplex] Layer : 2
INFO: [mplex] CRC checksums : no
INFO: [mplex] Bit rate : 28672 bytes/sec (224 kbit/sec)
INFO: [mplex] Frequency : 48000 Hz
INFO: [mplex] Mode : 0 stereo
INFO: [mplex] Mode extension : 0
INFO: [mplex] Copyright bit : 0 no copyright
INFO: [mplex] Original/Copy : 0 copy
INFO: [mplex] Emphasis : 0 none
INFO: [mplex] SYSTEMS/PROGRAM stream:
INFO: [mplex] rough-guess multiplexed stream data rate : 6177048
INFO: [mplex] target data-rate specified : 10080000
INFO: [mplex] Setting specified specified data rate: 10080000
INFO: [mplex] Run-in Sectors = 89 Video delay = 13019 Audio delay = 16773
INFO: [mplex] New sequence commences...
INFO: [mplex] Video e0: buf= 237568 frame=000000 sector=00000000
INFO: [mplex] Audio c0: buf= 4096 frame=000000 sector=00000000
++ WARN: [mplex] File size exceeded before split-point in video stream
INFO: [mplex] Starting new output file...
INFO: [mplex] Scanned to end AU 119978
INFO: [mplex] STREAM c0 completed @ frame 208464.
INFO: [mplex] STREAM e0 completed @ frame 119978.
INFO: [mplex] Multiplex completion at SCR=450297124.
INFO: [mplex] Video e0: buf= 54919 frame=119978 sector=01007058
INFO: [mplex] Audio c0: buf= 3424 frame=208464 sector=00069351
INFO: [mplex] VIDEO_STATISTICS: e0
INFO: [mplex] Video Stream length: 2030951516 bytes
INFO: [mplex] Sequence headers: 8121
INFO: [mplex] Sequence ends : 1
INFO: [mplex] No. Pictures : 119978
INFO: [mplex] No. Groups : 8121
INFO: [mplex] No. I Frames : 8121 avg. size 32788 bytes
INFO: [mplex] No. P Frames : 32023 avg. size 20788 bytes
INFO: [mplex] No. B Frames : 79835 avg. size 13765 bytes
INFO: [mplex] Average bit-rate : 3246400 bits/sec
INFO: [mplex] Peak bit-rate : 5687600 bits/sec
INFO: [mplex] BUFFERING min 15 Buf max 134306
INFO: [mplex] AUDIO_STATISTICS: c0
INFO: [mplex] Audio stream length 140088480 bytes.
INFO: [mplex] Syncwords : 208465
INFO: [mplex] Frames : 208465 padded
INFO: [mplex] Frames : 0 unpadded
INFO: [mplex] BUFFERING min 15 Buf max 683
INFO: [mplex] MUX STATUS: no under-runs detected.
/Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken.mpg is not a valid mpeg file
help69Guest
Did as suggested but I get this
Input #0, mpeg, from '/Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken-2.mpg':
Stream #0.0: Video: mpegvideo, 720x480, 23.98 fps, 5855 kb/s
Stream #0.1: Audio: mp2, 48000 Hz, stereo, 224 kb/s
Output #0, mp2, to '/Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken-2.mpg.mp2':
Stream #0.0: Audio: mp2, 48000 Hz, stereo, 224 kb/s
Stream mapping:
Stream #0.0 -> #0.0
**ERROR: [mplex] File /Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken-1.mpg unrecogniseable!
**ERROR: [mplex] Unable to read from /Users/christ/Desktop/KENTUCKY/KENTUCKYDVD/ken-2.mpg.mp2.
Originally Posted by help69
I also had the problem of ffmpegX creating a muxed 1.9GB .mpg, but producing an error before encoding the rest of the file. Since it was also my goal to produce a DVD, I simply used Sizzle 0.1 with the .m2v & mp2 to create a disk image, then burned the image using Toast 5. Would be nice to know why ffmpegX choked, but after several long encoding sessions I just wanted to finish the project.
GfD - Buttons invisible after creation on DVD
By michcio in forum Authoring (DVD)Replies: 4Last Post: 2nd Jul 2009, 17:22 -
Seagate Disk Wizard files invisible to Windows
By bevills1 in forum ComputerReplies: 0Last Post: 4th Apr 2009, 11:08 -
ConvertX mystery: invisible files ??
By Seeker47 in forum Video ConversionReplies: 5Last Post: 22nd Sep 2008, 00:59 -
PHP code used to generate code for Avysinth join mov and avi files
By lindylex in forum User guidesReplies: 0Last Post: 19th Sep 2008, 03:37 -
DVD to DivX using DVD decrypter, Auto GK experienceing error 2 code Help me
By timford101 in forum DVD RippingReplies: 6Last Post: 13th May 2008, 14:24
