  1. I've got a film that is in pal dvd format and is interlaced.
    when I try to convert it to vcd i get a shadow/ghosting type effect, so I used the deinterlacer (even field) in tmpgenc and this sorted this out but in turn created a jittery effect. So I changed the field order but the problem didn't go away!!
    I'v tried all the settings in tmpgenc but nothing works. The only thing that worked was the Even-Odd Field (fields) deinterlacer setting but this increases the frame rate to 50fps and I can't change the Fps to 25 because the jittery problem comes back.
    Are there any other ways I could deinterlace the image but keept the quality and smooth motion of the outputed vcd?
    Please Help!!!!!
    Cheers.
    Fingers Crossed That I get An Anwser.
  2. i had the same problem but are you sure you couldn't change the frame rate. are you useing a template then unlocking it? it's been a while since i had the problem. make sure the template is unlocked and try to change the frame rate again....
  3. I unlocked the templete but still the jittery problem. I think a better word for the shadow/ghosting type effect would be motion blur. I can't get round this one small problem!!
    If anyone can help then please do.
    Cheers.
  4. Open up in VDub, use the field bob filter, framserve to the application you want.
    ALTERNATIVE
    Use Avisynth, make script like
    AVISource=("C:\File.avi&quot
    BOB.selecteven
  5. What settings should I use for field bob?
