I have the Canopus ADVC-100 and have been using it successfully for a few weeks. But now I have a problem.
I've connected a VCR to the ADVC-100 via composite cables and am feeding it an older VHS tape recorded at LP (6 hours on the tape). Just inputting the first hour gives me an AVI file of over 60 gig. I cannot understand why this huge size when I haven't gotten such a big resulting file on other tapes. Just one hour yields a file over 60 gig!
Is this the ADVC-100 box doing this?
Am using Video Vegas 4.0 on the PC side to get the ADVC-100 input and do not see any options to moderate the input rate.
Thanks for any advice or considerations.
Have you changed how/what you capture with? I use ScenalyzerLive with my advc and the canopus codec. About 13G per hour.
It sounds like you are now capturing uncompressed with that file size. Did a codec change? Is this the first time you used Vegas? Try GSpot or AVICodec and see what codec is being used.
Need Help using AVStoDVD - Output size is HUGE
By Ronny G in forum Authoring (DVD)Replies: 42Last Post: 23rd Dec 2012, 21:27 -
Captured video huge in size
By Zooropean in forum Newbie / General discussionsReplies: 4Last Post: 25th Mar 2011, 16:55 -
ADVC 100 file size
By Honda617 in forum Capturing and VCRReplies: 8Last Post: 28th Jul 2010, 00:47 -
ADVC 100 and ADVC 300 non recognized in Windows
By scardi in forum Capturing and VCRReplies: 4Last Post: 28th Feb 2010, 02:23 -
ADVC-300 vs. ADVC-100
By DeadLily in forum Capturing and VCRReplies: 11Last Post: 19th Sep 2007, 09:15
