I've been trying to decide which "advanced" video editor to purchase. From what i've read, i like the sound of Vegas 4, but it appears a weakness is the mpeg encoder. Can you "plug-in" alternate encoders? This also goes for VS7 which I love for simple projects. Sounds to me like CCE is a great one, but I don't really want to deal with a two step procedure or framesurfing. I'd rather find out before spending $500 on vegas and another $60 on CCE.
Cleaner XL, Procoder and MainConcept all plug into Adobe Premiere. I use Procoder and the Adobe version of MC with Premiere. Works quite well.
Originally Posted by qlizard"There is nothing in the world more helpless and irresponsible and depraved than a man in the depths of an ether binge, and I knew we'd get into that rotten stuff pretty soon." -- Raoul Duke
Vegas uses MainConcept's MPEG codec.
but --- you can use also procoder, cce , tmpgenc , external main concept encoder , squeeze , ligos or just about anything else because you can frame serve from vegas with the free optional plug-in pac frame server"Each problem that I solved became a rule which served afterwards to solve other problems." - Rene Descartes (1596-1650)
How it possible Video: X264 encoder with Matroska encoder extension?
By flash_os in forum Newbie / General discussionsReplies: 1Last Post: 11th Feb 2012, 09:13 -
Any psychedelic or kaleidoscope effects plug-ins or software?
By johnharlin in forum Newbie / General discussionsReplies: 2Last Post: 26th Mar 2011, 08:57 -
Descriptions for Audio Effect Plug-ins-- Vegas 6.0d
By solarblast in forum AudioReplies: 4Last Post: 15th Nov 2008, 22:39 -
Anyone know good Video Editing tools? Sharpeners, plug-ins, grain, etc?
By HOTPROPHET in forum Newbie / General discussionsReplies: 4Last Post: 21st May 2008, 13:04 -
I'm wanting to cut some scenes and add some fade-ins to a DVD video.
By Ryan J in forum MacReplies: 4Last Post: 17th Apr 2008, 08:42
