hi
thanks for reading
i am quite desprate for help
you see:
i live in Singapore, PAL is being broadcasted here
i use huappuage capturing card
virtualdub with XivD codec for capturing to avi
i keep everything interlaced
i captured 2 different clips at different time.
later, i joined them using VirtualDub's Append avi segment
i fired up TMPGEnc, TFF, and encoded the appended avi to mpeg2
later i burn them onto DVD as DVD-video PAL
here comes the big problem,
i viewed 'em on TV,
!!onli the first part of the video is jumpy!!
the second part is perfect!!
damn...
so my question is:
izzit possible to change the TFF to BFF
for the first part of the video onli?
thanks for ur help in advance
Split it at the bad part, then reverse with RESTREAM
thanks for reply
sorry, i didn't notice i double posted it =p
can you help mi remove the other one?
thanks a million^^
ok, i have tried Restream
it works,
but there is a small problem.
TMPGEnc's MPG tools onli allows mi to cut at the nearest keyframe
but the bad part of the video came in where there is no keyframe -
To Be, Or, Not To Be, That, Is The Gazorgan Plan
yep, XviD does support interlacing
and the current XviD 1.0 RC2 had all the interlace bug fixed
i'm a bit tied on HDD space,
that why i use XviD instead of huffyuv
but, the acutal problem dosen't lie with XviD,
its the TFF and BFF flag in the PAL mpeg2 stream.
the keyframe i am referring is the MPEG2's intra frame
and not the AVI.
now i'm begining to regret deleting my AVIs
any1 have any idea to fix this problem,
without transcoding my MPEG again?
thanks for all ur help
Video Compression - Urgent Help needed!
By dberm22 in forum Newbie / General discussionsReplies: 4Last Post: 16th Sep 2011, 10:37 -
Urgent Help Needed to Save My Video Data
By lovehumanity in forum Newbie / General discussionsReplies: 1Last Post: 21st Mar 2011, 06:30 -
Capture video from a standalone DVD or? (urgent)
By prankstare in forum Newbie / General discussionsReplies: 2Last Post: 20th Mar 2010, 20:40 -
Video Advantage PCI: Interlaced Video/No Live Audio Preview/Other Questions
By acid_burn in forum Capturing and VCRReplies: 2Last Post: 8th Feb 2008, 20:03 -
URGENT: Search in video broken
By joape382 in forum Video ConversionReplies: 23Last Post: 28th Aug 2007, 09:06
