I do video editing in Adobe Premier and backup to DVD. I need to find a way to convert the .VOB files back to .AVI files in 720 line resolution so that I can make further edits.
I have tried to use the DVD2AVI and been able to convert back to 320 line resolution. I then found the "Huffy" driver/plugin, but when I save the AVI file that way it is not readable.
I do not have a problem pulling the DVD's back to the .VOB files. My problem is getting the .VOB files to .AVI files at 720 line resolution to where I can edit them.
Thanks in advance for any assistance on this.
John
It might not be the most elegant way or even the best way but you can convert a DVD (VOB files) to individual MPEG-2 files using TMPGEnc DVD Author. From there, converting to AVI should be easy.
? Are you sure you mean DVD Author? As far as I know it only goes the other way mpg2 to vob.
If it'll go the other way, how to do? I'm curious as I made the mistake of only saving the VOB files that had what I wanted in them to HD and want to edit and convert to another format so that I can accumulate enough small bits and pieces to put on one DVD without loading up the drive with complete DVD rips just for a 3 minute clip.
Cheers -
Yes, I author the DVD's as backup... When the AVI is 200 Mb per minute, DVD Video is a very viable backup, but I am finding that restore is another story.
Originally Posted by TBoneit -
I tried this, but it seem to only want to open .avi files. Will look at it again and see what I am doing wrong.
Thanks.
John
Originally Posted by lenti_75
removing background noise in AVI files created from .MOV files
By p_s_92 in forum Newbie / General discussionsReplies: 7Last Post: 23rd Jun 2010, 09:26 -
Making a DVD menu from .VOB files created by FAVC?
By whatever911 in forum Authoring (DVD)Replies: 9Last Post: 16th Feb 2009, 04:13 -
Nero converting vob to avi,,,files way to big after????
By jcurrieirocz in forum Video ConversionReplies: 7Last Post: 17th Nov 2008, 20:41 -
Converting .vob files to AVI
By abrathet in forum ffmpegX general discussionReplies: 1Last Post: 21st Sep 2008, 21:43 -
How are ifo files created with only vob files?
By Han Solo1 in forum Newbie / General discussionsReplies: 0Last Post: 18th May 2008, 14:07
