  1. I am trying to add a small clip frame to some video files in VirtualDub.
    Most files are ok, but this one file is going out of sync all the time.. (AVI) Is there something/option in VirtualDub to keep the audio and video in sync?
  2. Don't know if this will help you much but I noticed that nobody else has responded to your post the same as mine. (PRIVILEGE ORDER ERROR)
    I'm no expert but there is an option in VirtualDub under the Audio tab called "Interleaving". In there you will find "Audio skew correction". I have played around with that setting a little bit when I had a clip with the same problem you are having but I didn't have much luck. Understand that this applies the audio "delay" (or advance) to the WHOLE video.
    Good luck.
    NS
  3. awwwno there WAS?!?
    Darn.. I went into TempEngc and split audio and video, then dragged the audio into goldwave, added 16 seconds, then remerged them again in VirtualDub.. and there was an easier way.. sigh
