OK, let's see if i can explain myself properly.
I convert my .SSA subtitle with MAESTROSBT to the .SON format, i get the subtitle in .SON format and loads of bitmaps, then i import these .SON subtitle to DVDMAESTRO (to my project). Then in the menu i give the instructions i need like for the OFF button i check SET SUBTITLE TO 1 (my subtitle is on the first stream on the project) but i not check ON, and for examle for the portuguese subtitle i check SET SUBTITLE TO 1 (portuguese subtitle is on the first stream in the project) and i also check ON but i cant turn the subtitle OFF neither i can change to another subtitle language, it doesn't work. What am i doing wrong??? Some help please
THANKS
i just finished a disc and had the exact same problem, default was english, or no subtitle since the audio was in english, and i had 6 total tracks.
what i did was.. i made a dummy subtitle track, so there were 7 TOTAL(the english as 1). then when i wanted the subtitles off, i just choose the first subtitle track. of course i created a small subtitle in the editor, and all it said was "hi" in black, and made the subtitle appear in black, and voila, it worked... hope that was clear!
Problem burning subtitles and movie to DVD with Toast
By Akominatus in forum MacReplies: 40Last Post: 14th Apr 2013, 15:28 -
Problem adding subtitles to DVD
By makoto in forum ffmpegX general discussionReplies: 3Last Post: 15th Sep 2008, 14:25 -
Subtitles problem in DVD-lab pro
By spyart in forum Authoring (DVD)Replies: 1Last Post: 25th Aug 2008, 16:14 -
DVD WORKSHOP 2 problem playing subtitles
By Bella in forum Newbie / General discussionsReplies: 8Last Post: 2nd Jun 2008, 12:17 -
Problem getting subtitles with DVD Flick
By rich1842 in forum Newbie / General discussionsReplies: 0Last Post: 10th May 2007, 13:06
