  1. how do u convert a premade VCD, in mpegav folder, .dat file, back into an Mpeg file format?? help would be appreciated guys...!
    AMD 2200+ (1.83ghz), 512DDR PC2700 (333mhz)
    160GB Hitachi 7,200rpm 1mb cache, 80GB Western Digital/7,200rpm HD
    ATI Radeon 9600xt 128mb 8x, KT4 Ultra FSB 333 AGP 8X/ D bracket
    DVD+R/DVD+RW/CD-r/CD-RW,Antec Plus 1000 Case with lights
  2. Member Ziffelpig's Avatar
    May 2003
    Soviet Canuckistan
    Just shut up and listen dumbass
  3. thx for quick reply zifflepig....appreciated
    Jul 2001
    Sasarchiver,
    Though some people say otherwise, I've never had a problem with simply copying the '.dat' file to the hard drive and renaming to 'movie.mpg'.
    Easily done this dozens of times with no ill effect either making another VCD out of it, or, using it and a number of others to add a bunch to a single DVD. With DVD, I sometimes use besweet for fun to convert the audio first or just let MF2 do the trick while authoring.
    Have a good one,
    neomaine
    NEW! VideoHelp.com F@H team 166011!
    http://fah-web.stanford.edu/cgi-bin/main.py?qtype=teampage&teamnum=166011
    Folding@Home FAQ and download: http://folding.stanford.edu/
  5. You can also use lkvcdxrip and vcdxrip to do this as well. If you just copy
    the dat and rename it under the windows os, win will add a RIFF header to
    it.
    Also the copied dat/mpg will have vcd/svcd extentions. While this might be fine for normal playback and reburning to vcd/svcd you can run in to problems if your going to edit the movie.
    Just depends on what you want, but most suggest you convert it back to true mpg.
    Sabro
  6. hey neomaine, didnt know that!!! so i just copy the .dat file to the HDD and rename the file as .mpg? lol cool....
    To the other guy.....the reason i want to convert to mpg is to make a vcd/menu for the vcd i have....im not editing it at all, just through neros menu maker thing....
    Thx everyone, uve been helpful. Gordon
