Greetings,
Here is my dilemna. I want to backup a three episode disk.
When I use DVD Shrink, Here what I get:
Menu 158 Megs
Main Movie 7 Gbs
Extras 100 Megs
In the main movie, there is only one Title (Meaning one line) with 3 episodes.
My problem is the compression level is at 52%. I know the quality will suck.
Usually, when there is such thing, I am using NEro Recode and I disable the title. But I can't because the 3 episodes are in the same title.
So, is there a way I can split those episodes easilly (with software)?
Thank you
Using DVDShrink's Re-Author mode you can keep just your title, throwing away everything else (including unwanted audio and/or subtitle languages).
This will reduce significantly the compression, thus improving significantly the final quality. If you don't mind the extra time, you could also enable the Deep Analysis setting prior to backing up your movie.
You won't have a menu on your backup dvdr, but the 3 episodes will be shown as chapters of the only title, providing the original movie was factory-encoded that way. In that case, you can jump forth & back among the episodes using the |<< and >>| on your standalone's remote-control.
Best regards,
PS. You can also split the original title into 3 separate titles, using DVDShrink's Start/End feature (always in ReAuthor mode) but if the original title already contains 3 chapters (one for each episode) then I don't think it worths the extra hassle.
First Time Ripping...Looking for advice...
By zagro002 in forum DVD RippingReplies: 10Last Post: 19th Apr 2012, 00:07 -
Need advice: Splitting simultaneous recordings contained in WMV file
By asawadude in forum Video ConversionReplies: 4Last Post: 10th Feb 2011, 20:48 -
Advice required - Formats, splitting, software, outputs
By glinscott in forum Newbie / General discussionsReplies: 1Last Post: 19th Sep 2008, 08:00 -
Any advice for ripping a badly scratched disc?
By Bix in forum DVD RippingReplies: 27Last Post: 6th Jun 2008, 13:11 -
Need advice on ripping Region 2 Lost Highway DVD please.
By jwnulife in forum MacReplies: 17Last Post: 2nd May 2008, 19:13
