hi
Im having problems capturing DivX with a winfast 2000 xp expert
the audio is out of sync with video i've tried capturing with different audio codecs but still the same. help I really want to start capturing to divx!!!
thanks guys
Results 1 to 12 of 12
Did you try first capturing to plain .avi, then encoding to divx?
I'm not sure there is a processor fast enough to do realtime captures of xvid/divx and compressed audio - you must be dropping frames like mad. Capture the audio as pcm - do any audio compression afterwards. Do not try to capture as mp3. Your PC will not keep up with it. Also keep your framesize fairly low (640x480 absolute max). VirtualVcr is about the best I've come across for this.
This is from my own personal experience so I expect someone is going to prove me wrong! -
nah i didn't try capturing to avi first then rencoding to divX cos a half hour of uncompressed avi is 10GB and i gotta free up some space before i can do that wat program do you use to rencode and does it take long?
and it doesn't change anything capturing to a different partion.
Thanks for your replys! -
...ahem... XviD and DivX are video codecs, not audio codecs. That said, it's, like everyone say, not possible to do realtime DivX video encoding, specially if you're using mp3 audio if yopu don't own a real über system - You're effectively telling your system to DivX encode video in real time AND encoding audio to MP3 in real time simultaneously. Hell, my PIV1700 doesn't do only mp3 encoding much faster than real time! (slightly exaggerated...)xvid/divx and compressed audio
/Mats -
Mats,Quote:
I know this! I never suggested they were audio codecs - read it again.
And it is possible to do realtime divx/xvid capturing - just not with compressed audio as well. -
Xvid is better to capture with than divx which i found dropped too many frames,just had to tweak xvid a bit plus use pcm audio.
[/quote]Xvid is better to capture with than divx which i found dropped too many frames,just had to tweak xvid a bit plus use pcm audio
yep - totally agree -
Sorry feenix - Don't know how I got that wrong impression when I read it b4...Mats,
I know this!
/Mats -
thanks for your replys!!.
Is there any conversion guides for converting from uncompressed avi to divX/Xvid?
Or programs?
Thanks again -
VirtualDub comes to mind... Or DrDivX, sounds like it should work too...
/Mats
audio sync problem, how to work out progressive audio sync delay
By jolt321 in forum Newbie / General discussionsReplies: 13Last Post: 10th Apr 2012, 22:09 -
DV Type-1 to Divx video/audio sync problem.
By cgmarsh in forum Video ConversionReplies: 0Last Post: 10th Aug 2010, 16:35 -
Winfast tv 2000 xp
By Haopengyou in forum Capturing and VCRReplies: 5Last Post: 21st Jun 2010, 13:38 -
Winfast 2000 XP input jack is a PS/2?
By jabberdau in forum Capturing and VCRReplies: 7Last Post: 18th Nov 2009, 15:46 -
MPEG to Divx audio sync problem
By starless in forum ffmpegX general discussionReplies: 8Last Post: 11th Oct 2007, 05:38
