  1. i have an .avi of the series 24.
    i load up the avi on tempgnc
    then i convert the ac3 i have to .wav
    after this i load up the wav file and hit start
    tempgnc cuts off and dissapears.
    this happened when i tried to convert only fools and horses aswel.
    is this beacause it is to small a process for dvd convertion.
  2. How do you convert your ac3 to wav?
  3. Well that should do it OK.
    I presume TmpgEnc normally works for you - it's just these particular files?
  4. Check the avi for bad frames.
  5. When you say "cut out" did you get an error message ?
    If it's wet, drink it
    My DVD Collection
  6. no tempgnc just disapears without any error message
  7. I used to get this, re-install.
    My DVD Collection
