Actually, I've just had a thought. If the RAM is unstable at these speeds, could raising VDimm do for the RAM what VCore does for the CPU?
Perhaps I could raise the FSB to a speed it wouldn't boot at and raise VDimm to try to persuade it to go.
What do you guys think?
Cobra
Results 31 to 42 of 42
Right now is your memory set to be 100%? 100% of the FSB speed.
That could be why you are hitting a wall.
If you increase the voltage for the dimm then yes you could possibly go farther.
You could also try setting the memory so it is running at 166 just for testing. Then try to increase the FSB and see if the memory was the limiting factor. -
Originally Posted by Ducatti20
Piccoro,
Does RAM work in this way? I would have thought that it's the same as CPUs - at certain speeds, the processor does not make many mistakes but at higher speeds it does and becomes instable. Why is is that RAM is different, and setting it to 166 (therefore DDR333) will allow me to test its ability?
Maybe I'm missing something, just seems weird to me.
Thanks,
Cobra
EDIT: My memory is set to 100% (AUTO on Asus motherboards) -
OK, I've decided to change the RAM over to something else. What brand do you guys suggest? I don't have much to spend - up to £65 for a 512MB module. I only need it to run stable at DDR400.
Does anyone know a certain brand to be trustworthy?
Thanks!
Cobra -
I found a Kingston kit. If I run these dual channel, would I later be able to drop in another 512MB module into my third memory slot and maintain this pair in dual channel, whilst the other works single-channel mode?
Just worrying about future upgrade potential...
Here's what I'm looking at: http://www.ebuyer.com/customer/products/index.html?action=c2hvd19wcm9kdWN0X292ZXJ2aWV3...duct_uid=52643
Thanks for the quick reply!
Cobra -
Here's a good thread: https://www.videohelp.com/forum/viewtopic.php?t=209781
From what i gather, depends on mobo. -
Thanks, that helped a lot. I've ordered that RAM and it should be with me in a week or so. Here's hoping!
Thanks again!
Cobra -
Yeah, that was a pretty cool video and a "cool" project....
Most of the extreme coolers on overclockers site are running over 4 gig CPU's right now, the water cooled guys go from 800 mhz to over 3 ghz.. great site to hit up for research. Building my water system was fun, needed a project and benefited by reducing my computer noise.
Ex-AMD engineer rips AMD management
By deadrats in forum ComputerReplies: 0Last Post: 17th Oct 2011, 18:39 -
Chip Resetter - Will it reset "auto" 3rd party CIS Chip?
By RBYoshioka in forum MediaReplies: 10Last Post: 10th Nov 2009, 16:49 -
ECS GF8200a Mobo will not overclock w/ BE AMD 64 X2 5400...
By stedyone in forum ComputerReplies: 17Last Post: 27th Mar 2009, 02:40 -
AMD breakup; chip production now to be Arab-owned
By ahhaa in forum ComputerReplies: 8Last Post: 8th Oct 2008, 21:53 -
AMD 64 4000+(1x2.4GHz) or AMD 64 X2 3800+ (2x2.0GHz)
By neomaine in forum ComputerReplies: 19Last Post: 13th Jul 2007, 10:24
